Adding Taps and Tees in the same routing preference
Provide the ability to change from Tee to Tap depending on the size of the pipe.  The attachment shows when drawing chilled and heating hot water pipes, the type of fitting/material will change. i.e from Copper to Carbon steel depending on the size.
In the routing preferences we want to use off the shelf copper tees, however use taps for the carbon steel.  The routing preferences "appears" to allow for this however it's "locked" - this would be an excellent feature.
