Dimension snapping order
There should be a logical order of snapping when drawing dimensions (when there are concurrent references), e.g:
- Walls
- Columns
- Framing
- Floors
- Roofs
(the most important thing is that the dimensions don't snap to furniture, casework etc. first)
maybe this could even be a custom setting
2 Comments
h.bakkerPE58B
Completely agree. My workaround workflow now is isolating the categories and the dimension style before I begin dimensioning.
It would be great if in the dimension options (when placing dimensions) there was a option for selecting certain categories.
ipselute
@PieterL_TM We all know how incredibly bad the Revit dimensioning tool is. Revit should have resizable snap points and resizable grips like Autocad has. The most important option should be a Selection Cycling window like in Autocad, where you can select which object you want to select or to snap on.
