Analytical Elements
Analytical Elements
If you have two analytical panels that have a common edge (there is no gap between them), and if you move one panel trying to create a gap between them, the moved panel drags the other panel and lengthens its dimension. This behavior is the same for analytical members also. This behavior is not friendly if you try to copy an element right next to the other, then move one of them to create a gap between them.
We should have an option to choose if we want to drag the other connected analytical element if one of them is moved!
7 Comments
daniel.gheorghe5GJK4
Subscribe!
laura_negoita
Observer
I need this!
petrlanik
this feature is currently quite annoying, if you for example move one of bottom points of the wall, top nodes of any connected analytical member(column) move as well. In general editing of nodes offers several editing posibilities, but in practical use, it is easier copy panel or member or adjust the boundaries of analytical panel instead of trying to edit by nodes
ipselute
Maybe something similar to 'Disallow join" could be of help.
catalin_lang
Improving the analytical elements adjustments is in our attention.
What I noticed from the feedback we received so far, there are more than one situations. Therefore, each may need a different approach.
Revit 2026.3 brings a new capability - lock analytical model elements using pins - https://help.autodesk.com/view/RVT/2026/ENU/?guid=GUID-80ADB386-84DF-4FC2-990E-90B4001B47F4
Check the public roadmap to see few more improvements we plan - https://www.autodesk.com/customer-value/aec/revit
Thank you for your feedback!
I’d love to hear your thoughts and whether you see it impacting your workflow!
(view in My Videos)
Status changed to: Accepted
Congrats! We think this is a great idea, so we've decided to add it to our roadmap. Thanks for the suggestion!
To follow the progress of features in development, please see the Revit Public Roadmap and join the Revit Preview Release to participate in feature testing. (Note that Accepted Ideas may not be immediately available.)
Specific items from the Roadmap:
-The Factory
This is now available in Revit 2027! Thanks to everyone who contributed feedback - this directly influenced the feature.
Improved Control When Editing the Analytical Panel
 -The Factory
