Analytical Elements
Analytical Elements
If you have two analytical panels that have a common edge (there is no gap between them), and if you move one panel trying to create a gap between them, the moved panel drags the other panel and lengthens its dimension. This behavior is the same for analytical members also. This behavior is not friendly if you try to copy an element right next to the other, then move one of them to create a gap between them.
We should have an option to choose if we want to drag the other connected analytical element if one of them is moved!
4 Comments
daniel.gheorghe5GJK4
Subscribe!
laura_negoita
Observer
I need this!
petrlanik
this feature is currently quite annoying, if you for example move one of bottom points of the wall, top nodes of any connected analytical member(column) move as well. In general editing of nodes offers several editing posibilities, but in practical use, it is easier copy panel or member or adjust the boundaries of analytical panel instead of trying to edit by nodes
ipselute
Maybe something similar to 'Disallow join" could be of help.
