Dedicated Tool for Creating and Tagging Vertical Pipe Risers
The Problem
In hydrosanitary MEP projects, vertical pipe risers are one of the most critical and repetitive elements to document. Currently, creating a riser in Revit requires multiple disconnected steps: manually drawing a vertical pipe between levels, separately placing an annotation tag, manually typing the riser ID (e.g. AF-02, AQ-01), and then verifying that the tag style matches the system type — all repeated for every riser in the project.
This fragmented workflow is slow, error-prone, and inconsistent across team members. There is no built-in way to enforce a naming convention, automatically increment riser IDs, or ensure every riser is properly tagged on placement.
The Proposed Solution
A dedicated "Vertical Pipe Riser" tool in the Mechanical/Plumbing tab, similar in concept to the Column tool in the Structural tab, with the following behaviour:
1. "System type selection" — the user selects the piping system (cold water, hot water, sanitary, stormwater, supply, etc.) before placing. The tool inherits the correct pipe type and system classification automatically.
2. "Level span" — the user defines the bottom and top levels directly in the tool dialog, so the pipe is created at the correct vertical extent in a single click on the floor plan.
3. "Automatic riser ID" — each riser is assigned an ID following a configurable pattern (e.g. CW-01, CW02, HW-01) stored as a shared instance parameter, with auto-increment after each placement.
4. "Annotation on placement" — an identification tag (balloon annotation) is placed automatically at the point of insertion, using the tag family associated with the piping system, displaying the riser ID and nominal diameter.
5. "Riser schedule" — a built-in filtered schedule shows all risers in the current view or project, grouped by system, with their IDs, diameters, and level extents — enabling fast quality control.
Why This Matters
Riser documentation is mandatory in hydrosanitary and fire suppression permit submissions in many countries. Errors in riser identification (wrong ID, missing tag, inconsistent naming) are among the most common drawing review rejections. A dedicated tool would eliminate these issues at the source, saving hours per project and improving drawing quality directly.
This would be especially impactful for MEP engineers working on multi-story residential and commercial buildings, where dozens of risers across multiple systems must be coordinated and annotated consistently.
1 Comment
wr.marshall
