Both ends of Pipe Levels & Offsets in Properties
The ability to set both ends of a pipe levels & offsets independently of each other via the properties menu.
At the moment when you set the level it sets both associated to a level.
This fine for horizontal pipe runs.
However for vertical runs you then need to determine the top length that could go through a number of levels in a multi-story building. Having independently controlled levels will allow you more easily to determine vertical heights rather than manually working out what full height should be from the level which is likely to be the very base level.
Should you require a horizontal pipe the just set both to the same level and same offset
1 Comment
wr.marshall
Forma Design Contest
Technology Administrators
