cancelar
Mostrando los resultados de
Quiere decir:
Custom Insertion Point(s) for Leader Tag
It would be great if we can add custom insertion points for leader tags.
This would basically be an invisible dot you can place in your tag families.
I do realise you can create this effect with invisible lines, but it's a hassle!
When you have multi-line texts that wrap, it becomes very very hard.
36 Comentarios
james.vandezande
Allowing us to define a specific point in a tag family to which the leader would connect when the tag is place in a project would help us make better use of keynote tags displaying multiple lines of text.
ALTERNATE IDEA: An alternative to this proposal is to allow a text object to read a property of an object. Keep all the functionality of a text note (leader attachment options, stretchable boundary...) but provide an option to associate the text note to an object and a property of that object.
casquatch
I'd like to have a way to define the leader connection points for tags and annotation symbol families. I think this could be as easy as adding a feature to pin-point the spots in a family that I'd like the leader to attach to. If those don't exist, then the current default behavior is used.
For example, we'd like to have a wall tag with a note next to it. We can achieve the below result by placing two tags, which is not efficient at all.
When the above tag is edited to have a note within it, then we get this result:
As you can see, this doesn't work. No matter where the leader is, it's not correct or attached to the symbol.
Make this work better please. The current workarounds don't always work, and I don't think we should really have to do them in the first place. The tools should help us do our work the way we want to.
Referencing forum posts for this issue:
https://forums.autodesk.com/t5/revit-mep-forum/leader-position-on-pipe-tag/m-p/3942008#M19298
https://forums.autodesk.com/t5/revit-mep-forum/annotation-leader-spacing/m-p/7272192#M43414
Thanks!
Casey
Etiquetas (1)
No aplicable
casquatch
I searched around and didn't find anything related, but I'm sure my key words didn't match up. Well, hopefully we get enough votes either way!!
casquatch
To add to your post, it is a hassle, but sometimes you can't even achieve your intended look or tag by this limitation. Lets get it fixed!!
https://forums.autodesk.com/t5/revit-ideas/tag-annotation-symbol-leader-location/idi-p/7438315
No aplicable
No worries! The more exposure, the better I'd say.
casquatch
For whatever reason, when I paste in a link for any forum post of mine, it doesn't seem to actually work. Sorry about that! I also don't seem to have the ability to edit the post to remove it :cara_de_decepción:
No aplicable
Allow leader base point to be defined in generic annotation family. Currently the base point is auto defined by the extents of the content of the family. If the family is semi parametric you should be able to set the leader base points for all types. That way there is never a gap between the linework and the leader start point.
No aplicable
This is beyond obviously a need, especially with Revit's "automatic" leader connection points so totally random.  It calculates the "center of geometry", which, if just a little bit away from the desired point, seems unconnected.   This is also something they know how to do, since mechanical fixtures (hot water, etc) already know how to attach to an exact point.  If the currently random location were in ANY way controllable short of repeatedly editing the family (moving text, etc, until the leader attaches where you wanted), I'd be happy.  But clearly the best method is to add a "control" (similar to the arrows) that is a magnet for leader attachment.
jstroebel
 This is very annoying... Should be able to indicate the center of the tag by reference planes and use that center as the point for the leader...
eramoy
This could be solved if the leader origin "box" is not defined by its geometry, but defined by the Top, Bottom, Left, and Right reference planes.
No aplicable
The biggest issue I have with this is tags that have multiple visibility states.  I have different tag styles for multiple directions that contain a bunch of information and whenever I move the leader it jumps to Revit's "calculated" center based on seemingly nothing, but it's really just the hidden portion of my tag.
crapai
How is this still not implemented. It seems like a no brainer. I think another great addition would be to have a propertie for elements in tags that controls whether that elment is considered when caculating the leader location. Something like "Leader Location Contributer."
No aplicable
I would add my vote for this feature. I would propose introducing a line alone which the leader origin could travel as we change its direction
mmcintosh-ral
Please add a way to control a tag's  leader origin location.
When the leader's origin starts away/outside of a tag's shape/outline it is not clear that it is a leader from the tag- it looks like a mistake.
scbunker
Should also be able to specify at what points on the object being tagged the 'Attached' leader attaches to. Similar to this idea.
No aplicable
This is still killing me. You know how hard it is to implement Revit in an office when little things like this can't be controlled? It's a great way for leadership to fall back on "well AutoCAD does that really easily."
JLSMART
I'm looking at the weld symbol, which is a fairly complex symbol with leaders that work reasonably well. I can't figure out why it works or what all the constraints do. Can anyone explain it? The problem with the out of the box version is that it's too large. I want to make a half or two-thirds size version, but without understand the constraints, I can't make t work.
schlogl.robin
casquatch
@schlogl.robin, yes, this workaround can work in some situations, but not all....or most. It would be better to have this issue resolved so that we are free to build our tag families however we want and also be able to define the specific point(s) at where we want the leaders to snap to.
Enviar idea
