3d Text provides edge and center reference planes. However, when trying to constrain text to the center of the text vertically the constraints break, likely because the text sees itself as top aligned. Model Text needs to be able to be dynamically constrained to the the center of things, either by adding a vertical align parameter or by correcting whatever breaks when trying to constrain it otherwise.
Example: A family with identifying text which might need to be 2" or 3" high. The text can be constrained to the center vertically, but if the text size changes or the text content changes the constraints break.
This is a repost of archived idea: https://forums.autodesk.com/t5/revit-ideas/allow-3d-text-to-be-constrained-vertically/idc-p/9829211#...
