Connect Into Command using multiple families
I would like to be able to use the Connect Into command on multiple families instead of picking 1 family at a time.  For example, if you have 5 sprinkler heads in a row at various offsets on either side of a pipe.  If you pick one sprinkler head, Connect Into command comes up and I can connect into the main pipe.  Works great.  If I pick more than 1, the Connect Into command isn't available.  It would be very fast and more usable to have this function on a group of sprinkler heads to connect into 1 pipe.  1.jpg2.jpg3.jpg4.jpg
1 Comment
pieterdewaal
This feature would save a tremendous amount of time. It is much faster using connect into for terminals to ducting/piping; however, it is still rather ineffective as each terminal has to be routed individually.
This functionality is comparable to trim vs multi trim: multi trim allows multiple pipe/duct extensions and taps/tees into a master pipe. Of course, there must be enough space for all fittings etc. to be routed.
