Changing schedule settings honour selection
I propose that switching from the spreadsheet editor to the schedule's properties window should honour the user's current selection. That way you can edit the column you currently busy with and not always fall back to the first entry. Similarly it would be great if adding a new field adjusting its position and continuing with its format would not revert to the first entry.
