Change Project Parameters name
Why not we couldn´t just change the parameters name? 😞
2 Comments
RPTHOMAS108
Support for non-shared project parameters should be removed as this would be the first step in allowing the name of a parameter to change. Wider than this suggestion however is that we work in a global environment so it should be possible for a shared parameter with a certain GUID to have many localised names. It is simple logic really.: If the parameter has a name specific to one language region then that gets used for all regions If parameter has a multiple names then the region specific one is used or default English (English is a good default for me...I don't have to do anything). Say I add a parameter name then transfer the project to my non-English counterpart they could then assign their own names in a second language (or I could do that to start with in my global content).
JesikaDG
I wanted to note that setting Element.Name for Global Parameters is allowed and works. I would expect the code flow for Project Parameters to be similar and would hope that it wouldn't be hard to accomplish.
