A Snap overrides little enhancement but powerful feature
Its a little feature enhancement request
PROBLEM : -
While Using snap to intersections sometimes I attach the object to other snaps.. to cope with this error as far as I know there are two options
1. Snap overrides : yes it is a good feature but work only for single time. If I have to put say.. a beam at like 10+ number of time in single chain then I have to each time right click then select snap override then intersection for each time I place on column, which will disturb my flow therefore not viable because instead I can zoom and select the intersection myself : (Maybe I want that while placing it only and only snaps to grid intersection at each click uninterruptedly for temporarily for as long as I want).
2. Or I have to open snap settings > manually uncheck all other snaps except the ones I need and then again select the unchecked snap options when my beam placement is done. but the problem if while checking and unchecking is tedious and also not easy to remember what are default snap settings I was using before.
(If there is already a solution for this problem please suggest me and I am sorry for wasting your important time)
IDEA : -
Now my idea is while using snap override we can put a toggle option to enable and disable the snap override whenever needed which will according to me best and convenient way or we can add a save&load setting section in the snap settings where user like me can customise and save snap settings for different occasions then load them whenever needed.
I think if this feature is added may be it will make Revit more easier while modelling 🙂 .
Thank you
1 Comment
Status changed to: Archived
Thanks for taking the time to submit your idea. Unfortunately, this idea did not get the support of the community (votes or comments) over the last 24 months. Please feel free to re-word (titles and clear descriptions for specific features or enhancements are very important) and resubmit this Idea.
