Budgets integrated into Revit or a native extension
I have successfully integrated budgets natively into Revit, using a category as a database. Budgets update in real time, and I can access all calculations related to a specific item, including labor costs and a detailed breakdown of materials, without the need for modeling.
This is particularly interesting when working exclusively in an Autodesk environment. I’m aware of existing budgeting software, but developing this functionality natively in Revit doesn’t seem as complex as it might appear.
If any developer is interested, I’d be happy to share more details, or if someone has already worked on something similar, I’m very eager to learn more about it.
3 Comments
jorgeguachalla78808
(view in My Videos)
CarolinaRamirez_es
Hi @jorgeguachalla78808
There are specific programs for measurements and budgets, for example, Presto.
You can manage the data and the project.
https://youtu.be/FzKL9ng9ch4?si=Pz3_yD89HSNj_3kX
Regards
jorgeguachalla78808
Si se puede hacer con revit y es muy potente ,ahora con respecto a las categorias que no aparecen en materiales , no es porque quiera el area de las tuberias o barandillas sino , unificar todo en una tabla con todas las mediciones y es posible
https://www.youtube.com/watch?v=9G_TwJdGuJ4&t=43s
