When syncing large cloud-shared Revit models with many users (10+), it is possible to get stuck in a sync loop. In nightmare scenarios, users repeat Reload latest for 45+ minutes. Here is an example of a user on an x8 sync attempt.
Adding to this problem, BIM360 syncing doesn't seem to respect who pressed sync first. We believe Reload latest is a race to the finish- and the first user done gets to Save to central. Unfortunately, if a user hasn't synced in awhile, their Reload latest takes longer. Because of this, they get booted to the back of the line multiple times as other team members pass them by. The bigger the team, the bigger the problem.
My idea is to introduce a sync order that is initiated after Save to local but before Reload latest. Hopefully this will reduce or eliminate the possibility of a sync-loop.
/AK
