Revit Cloud Worksharing Sync Queue
We've all been there. Multiple users working on a central model coordinating who can sync when, either through the work-sharing monitor or a parallel group lync chat.
This has always seemed super inefficient to me.
My idea for C4R would be a stacking queue, so that while one sync is taking place you can add your sync to the queue so that yours will automatically be processed once the central model is available.
With this in place its not an un-imaginable leap that by knowing how may syncs are in the queue and volume of data that need to be transferred that an estimated waiting time could be given allowing users to plan their work and syncing more effectively.
19 Comments
KirkWM
Great idea!
had the same idea, just with a feature more like it would close Revit after its done sync and saving. closing most worksets so only 1 is left open (For faster sync).
This would be great for project that are large in terms of a how many works in the file itself. so many time, i and other colleges have to spent an hour or more extra at work due to sync can take too long or people sync at the same time, since they click at the same time right after one is done sync on workshare monitor. This way you would never had two or more sync at the same time, by simply having a queue system.
if this was a feature you could simply push the add me to sync queue, pack your stuff and head home from work. then have a script on windows closing the PC once revit is closed.
tom_hughes
Hi Tobias, I do like your idea especially if you are having to wait for up to an hour to get your work synced before you can leave work.
I don't know how agreeable IT would be about having machines left un-attended and being closed down by script? I know at my company they don't allow it due to security considerations.
Perhaps there is a way to do something where your sync is queued and the sync data is cached alongside the central model. That way you can close down your machine and when your sync gets to the front of the queue it can be handled without you?
How about other people on this posing do you need to be able to 'sync and forget' at the end of the day? Would your IT let you have a 3rd party app close down your computer?
Ian.Ceicys
Tom and others,
We agree with you guys on this one.  If we had a queue, what would be your expectations of the experience?  Would you want to see who else is in the queue?  Be able to drop off the queue once you got in it?  Something else?
-Kyle
tom_hughes
Hi Kyle,
In my mind yes, it's a visual queue that you can see who is currently syncing and who else is in the queue. It would be really good if the queue time could be estimated by the amount of data people have to sync back to central.
It would be great if the queued syncs could be cached temporality alongside the central model so that whenever anyone syncs the would never get a message saying that the central model is in use.
When someone else is syncing you might be given option like 'Add to Sync Queue and keep working', 'Add to Sync Queue and exit Revit' & 'Wait until later' to suit the use cases that people have talked about in the thread above.
How would a queue system work with conflict resolution? Multiple workers can be performing contradictory operations on the model. What would be the outcome of going through a sync queue? It is conceivable that half way through the queue elements that are still expected to exist further down the queue might no longer exist. What happens then?
@Anonymous Revit's Element Borrowing functionality prevents conflicts from happening, so a queue system wouldn't change that.
-Kyle
Jake.Popkin
Observer
Any progress with this item? I support everything Tom's stated above, a sync queue would be greatly appreciated.
aking-watg
When syncing large cloud-shared Revit models with many users (10+), it is possible to get stuck in a sync loop. In nightmare scenarios, users repeat Reload latest for 45+ minutes. Here is an example of a user on an x8 sync attempt.
Adding to this problem, BIM360 syncing doesn't seem to respect who pressed sync first. We believe Reload latest is a race to the finish- and the first user done gets to Save to central. Unfortunately, if a user hasn't synced in awhile, their Reload latest takes longer. Because of this, they get booted to the back of the line multiple times as other team members pass them by. The bigger the team, the bigger the problem.
My idea is to introduce a sync order that is initiated after Save to local but before Reload latest. Hopefully this will reduce or eliminate the possibility of a sync-loop.
/AK
Tags (4)
ADiVenere
I have the same issue on my BIM360 project. We've had synchronize times up to 3 hours because of the que.
Currently on try 12.
Autodesk please help with this as syncing can take up much needed time. It also does not help much for collaboration when working in a different offices. A queuing system will help tremendously.
eric_hansonOEG
Is there an update to this? This is really slowing my team of 40 down.
Status changed to: Gathering Support
To reorganize and consolidate our Revit Ideas for ease of use to both our customers and our product teams, we are no longer using the "Future Consideration" status for Revit Ideas. All Revit Ideas are always under review, and consolidating posts (and Kudos!) will give weight to topics previously spread across many posts. We are continuing to evaluate where this request falls into our roadmap and will provide an update when we have made a decision.
Thank you for your contribution!
-The Factory
DGuenter
We've been having this problem on a well managed model with only 6 people for weeks. Reload latest is consistently taking +45mins-1hr, even if users sync sequentially. Our Design Tech team can't figure it out, neither can our Autodesk support staff. So stumped and extremely frustrated... burning so much fee for nothing.
Revit - so smart, it's actually stupid.
stephen.millard
agree, this is holding everyone up on all the projects I run - please sort ASAP
Status changed to: Accepted
Congrats! We think this is a great idea, so we've decided to add it to our roadmap. Thanks for the suggestion!
To follow the progress of features in development, please see the Revit Public Roadmap and join the Revit Preview Release to participate in feature testing. (Note that Accepted Ideas may not be immediately available.)
The Factory
cbeckerN4PUL
On a large project model with multiple modelers syncing throughout the day, Autodesk needs a temp cloud buffer location that can absorbs everyone's syncs and then feeds them into the model in order. Like Github for BIM, fast local commits, then a controlled merge upstream.
1. Everyone syncs instantly to the buffer.
2. The central model ingests them one at a time.
3. Nobody gets locked out.
4. Nobody gets  "cant edit element"
5.Nobody gets the 5 minute freeze
6. Nobody corrupts the central model by syncing at the same millisecond.
Please Autodesk, bring us in to the modern world.
Ric_Weber
