Currently, the setup of the default setting for open Worksets is possible only when saving a new central file. The alternative is to use the Options while opening the file, which must be adjusted each time.
The suggested functionality will be to have the opportunity to change the default settings for open Workset for an active central file without creating a new central. This would avoid the creation of a new central file and thus maintain the version history and the link connection between the files.
