Add visibility graphic option to toggle on void forms
Working with void forms can be frustrating at times, due to the lack of visibility. They can be hard to locate in projects and families and are often a chore to work with, requiring filtering to select. Adding a visibility option under the massing category to voids, would be extremely helpful to easily locate and manipulate void forms.
Cheers
7 Comments
iCs-tna
VOID's don't own the parameter of visibilty. Adding this parameter to VOID's would give additional options to control families and give different appearence. Also it would make it possible to reduce amount of families for certain problems.
awasyliw
I'm not sure what benefit this would have. Hiding geometry doesn't change the effect of its interaction with other geometry. That's the reason that joined geometry shares a single visibility parameter, because family geometry interactions are not changed when things are turned on or off, it is purely a visibility action.
Implementing this would require the entire way family geometry is calculated to be changed. I agree it'd be useful,m but it seems a huge ask.
nihalmehdi
helpful suggestion.
It will be very good.
onuresen50
Great suggestion, hope it'll be accepted
I think the idea would be that visible would turn the cutting on/off.
That said, there's already a popular post requesting this: https://forums.autodesk.com/t5/revit-ideas/void-visibility-parameter/idi-p/6456982
wr.marshall
When a Void cuts an object it disappears. Sometimes a modification is required on the void. Now there is a preview button at the bottom to turn visibility on/off. Perhaps add an option here to turn voids on/off. When turned on the voids even though cutting solids would be visible.
Tags (5)
wr.marshall
Current View
Proposed view
