Able to still select elements when Visibility/Graphic Overrides Window Open
It is frustrating when trying to control the visibility of objects when you constantly have to go open the VG window turn on/off the necessary sub category then close window and go perform required actions on your model only to find you need to turn something else on/off to continue. Recommend that selection of objects within the drawing area should still be selectable even if the VGO window is open.
6 Comments
wr.marshall
Zin_Phi_
If the V/G window is open, it is no longer possible to continue working. It would be nice if the V/G window could be handled in the same way as the properties window. It is often quite time consuming to enter the V/G window, switch to the filter views, set filters and back again
If the V/G window can remain open and the settings are applied immediately (without having to click on Apply) you save a lot of time
tristan_haehnelQST3F
Allow users to work with vv window open
Currently, the 'Visibility/Graphics Overrides' workflow requires a final confirmation before being able to interact with the 'Floor Plan' view. It would be more intuitive if this confirmation were optional, allowing users to make real-time changes, or better yet, to apply changes and immediately interact within the 'Floor Plan' view.
mbeamerX2XBH
Community Visitor
Would be excellent to be able to keep accessing the model while the V/G panel is open.
Often when setting up a view I'm opening and closing V/G panel repeatedly. Would be nice to avoid if possible.
Agree to all above. Having the Visibility graphics window to be open all the time while modelling as a user interface such properties/project browser, would make modeling more effective and time saving.
