Ability to define room bounding elements in familes.
Right now room bounding can only be defined at the project level.  There are occasions where the ability to mark a family as room bounding (or not room bounding) would be helpful.
Custom openings
  • We use a family instead of the wall opening tool because it will phase correctly, and is easier to control the size and location of a family.  There are also instances where a repetitive custom opening would be required (arches, etc.)  Depending on the design, these are often not room bounding.
  • For example an alcove in a structural wall.  Because the opening family is treated as room bounding the room does not report it's area correctly
6 Comments
andydandy
Yes! We've had cases where we would have needed room-bounding beams, for example.
sasha.crotty
Thanks for taking the time to submit your idea. Unfortunately, this idea did not get the support of the community over the last 6 months and as such we will not be pursuing it at this time. Please feel free to rework (titles and clear descriptions are really important) and resubmit this one down the road.
sasha.crotty
Status changed to: Archived
sasha.crotty
sasha.crotty
I think this might solve your issues- if you agree please share and vote for it!
Rules per view for calculating ROOM Areas
https://forums.autodesk.com/t5/revit-ideas/rules-per-view-for-calculating-room-areas/idi-p/11464439
