Right now room bounding can only be defined at the project level. There are occasions where the ability to mark a family as room bounding (or not room bounding) would be helpful.
Custom openings
- We use a family instead of the wall opening tool because it will phase correctly, and is easier to control the size and location of a family. There are also instances where a repetitive custom opening would be required (arches, etc.) Depending on the design, these are often not room bounding.
- For example an alcove in a structural wall. Because the opening family is treated as room bounding the room does not report it's area correctly
