The light is driven by a Photometric Web File. There is none assigned to it. If you aren't familiar with IES files, which are required, then change your Light Distribution (property of Light Source Definition) to something other than Photometric Web.
NOTE: If you are downloading Light Fixtures from Manufacturers, chances are good that they also offer IES files on their website that you can download as well.
....Ah! and @piotr.bocian is correct; the light source inside solid geometry. I don't know why the geometry exists, but it's unnecessary. I deleted it and changed the Light Source Properties , as I described above, and attached herein for you to try.
