- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Can somebody help me. I added a shared parameter called DRAFT.
If i put YES in the parameter the text DRAFT should appear on the sheet heading.
But it doesn't work, it only works if I first select the title block and then press it.
And i can assure your, if you have 100 plans where you have to put draft on, you do not want to open every sheet, click on the title block and put the draft on.
As you can see on the images underneath. The box on the sheet can be unchecked and DRAFT will still be placed, it's the box on the titel block that creates it.
Anybody a sollucion?
