Can somebody help me. I added a shared parameter called DRAFT.
If i put YES in the parameter the text DRAFT should appear on the sheet heading.
But it doesn't work, it only works if I first select the title block and then press it.
And i can assure your, if you have 100 plans where you have to put draft on, you do not want to open every sheet, click on the title block and put the draft on.
As you can see on the images underneath. The box on the sheet can be unchecked and DRAFT will still be placed, it's the box on the titel block that creates it.
Anybody a sollucion?
Solved by ToanDN. Go to Solution.
Is the draft parameter added long time ago or you recently added in? If you added in and have it check ON, it will set to that state as default. If you decided to check it off in the family and load it back into project, it won't respect your changes. One way I make this work is to select the family inside the project. You can right click on the titleblock and select all instance in entire project
You should see in your properties number of titleblock in your project. You can check that DRAFT off.
I would then set up global parameter so next time you can go to Manage>Global Parameter, you can turn ON/OFF the parameter and it will apply to all the titleblock you have selected
Thanks for the help!
Hey everyone,
Very helpful to see that I wasn't the only one loosing my mind over this. My solution was to just write a Dynamo Script which pulled information from the sheets and put it in the titleblock on that sheet. I select all sheets in the project browser to apply a specific parameter, then run the script to push the parameters into the titleblock.
Hey everyone,
