Revit 2023 TTR
6 REPLIES 6
PhilvK
382 Views, 6 Replies
Revit 2023 TTR
Revit 2023 is supposed to have the circle TTR option. I can't find it or any YouTube videos showing how to access that function. Am I missing something obvious?  Thanks!
6 REPLIES 6
in reply to: PhilvK
Where did you get it from?
PhilvK
in reply to: ToanDN
From Account > Products and Services (??)
in reply to: PhilvK
Not the software, but the idea of TTR availability.
PhilvK
in reply to: ToanDN
I thought I read it somewhere or saw it in a video tutorial. Obviously dreaming or wishful thinking.
Mike.FORM
in reply to: PhilvK
It would appear this option as well as the TTT option are available in AutoCAD only and haven't made their way into Revit yet.
https://knowledge.autodesk.com/support/revit/learn-explore/caas/video/youtube/lesson/144292-courseId...
The work around would be to draw two lines coincident with the lines you want to be tangent too (if it is a wall face or something else modeled) and use the fillet arc specifying radius to find the circle centerpoint location. Then draw your circle.
PhilvK
in reply to: Mike.FORM
Yeah, TTR's been in AutoCAD forever. As I mentioned in response to ToanDN's post, I thought Revit 2023 was to have that capability.
Forma Design Contest
Technology Administrators
