Revit 2023 TTR
Revit 2023 TTR
PhilvK
Advisor Advisor
Revit 2023 TTR
PhilvK
Revit 2023 is supposed to have the circle TTR option. I can't find it or any YouTube videos showing how to access that function. Am I missing something obvious?  Thanks!
Where did you get it from?
PhilvK
From Account > Products and Services (??)
Not the software, but the idea of TTR availability.
PhilvK
I thought I read it somewhere or saw it in a video tutorial. Obviously dreaming or wishful thinking.
Mike.FORM
It would appear this option as well as the TTT option are available in AutoCAD only and haven't made their way into Revit yet.
https://knowledge.autodesk.com/support/revit/learn-explore/caas/video/youtube/lesson/144292-courseId...
The work around would be to draw two lines coincident with the lines you want to be tangent too (if it is a wall face or something else modeled) and use the fillet arc specifying radius to find the circle centerpoint location. Then draw your circle.
PhilvK
Yeah, TTR's been in AutoCAD forever. As I mentioned in response to ToanDN's post, I thought Revit 2023 was to have that capability.
