Revit 2023 is supposed to have the circle TTR option. I can't find it or any YouTube videos showing how to access that function. Am I missing something obvious? Thanks!
Solved by Mike.FORM. Go to Solution.
From Account > Products and Services (??)
Not the software, but the idea of TTR availability.
I thought I read it somewhere or saw it in a video tutorial. Obviously dreaming or wishful thinking.
It would appear this option as well as the TTT option are available in AutoCAD only and haven't made their way into Revit yet.
The work around would be to draw two lines coincident with the lines you want to be tangent too (if it is a wall face or something else modeled) and use the fillet arc specifying radius to find the circle centerpoint location. Then draw your circle.
Yeah, TTR's been in AutoCAD forever. As I mentioned in response to ToanDN's post, I thought Revit 2023 was to have that capability.
