How do I mirror this text to orient the opposite direction? Thanks
Select it, edit type, then down to read convention (under text). Though I think you may be a little limited since it looks like it is just slightly off of orthogonal.
mhiser said, just go into EDIT > scroll down and go through the options of the list ' read convention'
It might not be obvious which one it is so just try them all as it depends what rotation you have in your sheets and viewports as to how its trying to orientate itself. all up, then left, up, then right and all that will change it.
