Insert a larger Wall Opening and measure it.
Or, create a curtain type with the "10 mm shim" as the border frame, no divisions. Insert it in the wall and set the size = the rough opening. Nest the original Curtain wall in it as the panel.
Similar topic: https://forums.autodesk.com/t5/revit-architecture-forum/challenge-extended-dimension-reference-built...
Toan Nguyen
![EESignature EESignature](http://autodesk.i.lithium.com/t5/image/serverpage/image-id/1272565i464DC3DC646B4F11/image-size/original)
