Show only
Search instead for
Possible to dimension the frame width instead of wall opening?
Hi!
I wonder if there's a smart way of getting frame width instead of wall opening when measuring curtain walls? Here's a picture (in Swedish) showing the problem. Working as intended for doors but not curtain walls:
Or, create a curtain type with the "10 mm shim" as the border frame, no divisions. Insert it in the wall and set the size = the rough opening. Nest the original Curtain wall in it as the panel.
