Line work caused a strange problem
5 ANTWORTEN 5
Nachricht 1 von 6
m.pharamawy
374 Aufrufe, 5 Antworten
i noticed that when i use line work, then the mouse catches the overhead floors.
when i am in ground floor,  when hovering the mouse it catches the first floor roof, vises versa when i'm in first, it catches the  roof floor.
it's not a big issue but it's annoying.
i need to know if that was caused by line work really? or another reason, and if anyone had the same issue and what shall be done to solve this
5 ANTWORTEN 5
Nachricht 2 von 6
constantin.stroescu
als Antwort auf: m.pharamawy
maybe this happens bInkedlarge_LI.jpgecause you have activated the option: Select Element By Face.....Deselect it.
Constantin Stroescu
Nachricht 3 von 6
m.pharamawy
als Antwort auf: constantin.stroescu
negative. i always activating this option but the problem occurs
concurrently with the usage of the line work.
Nachricht 4 von 6
constantin.stroescu
I had a similar experience with Linework tool when I want to show in a floor plan the roof projection using Linework - Overhead.
After closing the underlay ( Roof Level), when I am trying to select something on my floor view I had difficulties and I had to zoom in in order to be able to select that entity from the level, otherwise the Roof Level will select....
But, I can overcame this by selecting the Roof Linework, Pin it and from the Status Bar(far right) uncheck Select Pinned Element.
Constantin Stroescu
Nachricht 5 von 6
m.pharamawy
but u cannot select line works, u selected the floor it self.
Nachricht 6 von 6
Use TAB to cycle through the selection.
How about lower the Top View Range to below the bottom of the floor/ceiling above?
