Possible to dimension the frame width instead of wall opening?
1 REPLY 1
Marcus.Isacsson
455 Views, 1 Reply
Hi!
I wonder if there's a smart way of getting frame width instead of wall opening when measuring curtain walls?
Here's a picture (in Swedish) showing the problem. Working as intended for doors but not curtain walls:
1 REPLY 1
in reply to: Marcus.Isacsson
Insert a larger Wall Opening and measure it.
Or, create a curtain type with the "10 mm shim" as the border frame, no divisions.  Insert it in the wall and set the size = the rough opening.  Nest the original Curtain wall in it as the panel.
Similar topic: https://forums.autodesk.com/t5/revit-architecture-forum/challenge-extended-dimension-reference-built...
Forma Design Contest
