Welcome to Autodeskā€™s Revit Architecture Forums. Share your knowledge, ask questions, and explore popular Revit Architecture topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Instance parameter length+count in Schedule
4 REPLIES 4
5171 Views, 4 Replies
hello,
i have this  simple pipe generic model family (attached) with a length as instance parameter.
now im placing the family several times in different lengths (the length is instance parameter because i need the grabbing snaps).
is there a way to show specific length parameter in the  generic model schedule? and also to count the total length of all the pipes in the project.
its probably very simple but i couldn't find a way.
thanks!
4 REPLIES 4
Use a Shared parameter for Length and you can add it to your schedule. To get the total, go to Format tab of the schedule, select Length field and choose Calculate Total, then go to Grouping tab and set the footer to report Total and Count.
in reply to: ToanDN
thanks for the quick answer,
i tried to make shared parameter of the length, but the problem is the shared parameter disable the option for instance parameter so all pipes are the same length and cant be adjustable with instance parameter.
how can i keep the length adjustable?
You can set shared parameters to Instance or Type the same way you do to non-shared parameters.
Sure. Calculate Totals of Parameter Field and include it in Sorting and Grouping Tab and set as Header or Footer.
Forma Design Contest
