hello,
i have this simple pipe generic model family (attached) with a length as instance parameter.
now im placing the family several times in different lengths (the length is instance parameter because i need the grabbing snaps).
is there a way to show specific length parameter in the generic model schedule? and also to count the total length of all the pipes in the project.
its probably very simple but i couldn't find a way.
thanks!
Solved by barthbradley. Go to Solution.
Solved by ToanDN. Go to Solution.
thanks for the quick answer,
i tried to make shared parameter of the length, but the problem is the shared parameter disable the option for instance parameter so all pipes are the same length and cant be adjustable with instance parameter.
how can i keep the length adjustable?
Sure. Calculate Totals of Parameter Field and include it in Sorting and Grouping Tab and set as Header or Footer.
