Installitation incomplete. Some products failed to install
I got a student license from you guys and I really appreciate it, but i´ve been trying to install Revit 2016 in my laptop and it fails everytime.
I have windows 10 but I don´t believe that´s the issue, i saved the error logs to see if your guys can read through it and encounter the issue for me.
Thanks for your time.
RDAOU
Hello @Anonymous
You are using direct install which many has been experiencing issues with; try to download the software from Autodesk Virtual Agent - It should download in parts. Once complete, extract part one to the default directory C:\Autodesk. Installation should begin once all part are extracted to this directory.
Note:
  1. Have any Antivirus/Firewall disabled temporarely
  2. Add Autodesk.com to safe/white list
  3. Insure you have admin rights
  4. Some users reported installing offline (Network and Internet) helped (Can not confirm)
Sent from my Iphone
TravisNave
Your installation is failing on the Medium Installation Library install.
Install	Autodesk Material Library 2016 - Medium Image Library	Failed	Download Failed, Installation aborted, Result=1603
You can download and install this manually from this link:
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to...
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Thankyou so very much, I did as you said and it worked out perfectly.
Thankyou for your assistance Travis, It worked out for me.
