Welcome to Autodeskā€™s Revit Architecture Forums. Share your knowledge, ask questions, and explore popular Revit Architecture topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
How to let families show through a filled region
3 REPLIES 3
jswoolley
785 Views, 3 Replies
So, I'm cleaning up a site plan and I realize someone (I swear it wasn't me!) drew the site as filled regions. Ridiculous, right!? I would have drawn it as subregion topography! My question is, if I want to place more components in the view (such as this truck), how can I get it to show as white through the filled region, barring redrawing the whole thing as subregions? My best guess is to trace a hole in the filled region that's the same shape as the component. That would be a pain in the ass, so if you know better solution, please let me know!
3 REPLIES 3
in reply to: jswoolley
Just use Visibility and Graphics Overrides for the element or category.
jswoolley
in reply to: barthbradley
I should have know that. Thanks for the reminder.
loboarch
I just replied in another thread to a very similar issue. If using 2019 the setting in the type properties of the filled region is slightly different than in previous versions.
https://forums.autodesk.com/t5/revit-architecture-forum/transparency-of-filled-region-revit-lt-2019/...
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Forma Design Contest
