I created a cabinet family and I can't figure out why the default rotation point, when placed in project, is 3ft over from the center of the cabinet, were it should be. (See Picture below)
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Clean the family up. Sounds like some extraneous information (e.g. Ref. Lines.) are being recognized and included in the extents. Keep in mind that Ref. Lines can be labeled "not a reference", "weak", "strong", etc.
...and "origin" ![]()
I don't know what could be causing this, because I have other similar cabinets without this problem. If you have the time to see the URL below, you'll see the cabinet. I think it's cleaned up pretty well, but obviously there's something going on.
https://tmisystems4-my.sharepoint.com
I found the issue. i had a small ref plane located far right of the geometry.
Thank you for the response and your time!
