Door Swing Direction in Schedule
87 REPLIES 87
Message 1 of 88
17787 Views, 87 Replies
I spent the better part of the day on the web learning that Autodesk did not include the ability to include and update door swings automatically. I did find a few apps but before I spend any cash on them I am hoping someone here has some additional options I have overlooked.
Todd
87 REPLIES 87
Message 41 of 88
in reply to: Ian_H
@Ian_H wrote:
So I came across this thread and I can't seem to get the script to work.
-I manually added the 'Door Set' text parameter
-I edited a couple of the doors families in my project with the 'Room Calculation Point' turned on
-My phasing I selected is correct
I am getting a 'Dereferencing a non-pointer' error. Someone else had this error and said it was related to phasing, but like I said the phasing selected was the phasing for the doors in the project.
Any ideas?
Can you share a screen showing the script and the error?
Message 42 of 88
Ian_H
in reply to: ToanDN
Message 43 of 88
in reply to: Ian_H
Check if "Door Set" is a text parameter, spelled correctly, and assigned to Doors category.
Message 44 of 88
Ian_H
in reply to: ToanDN
Message 45 of 88
in reply to: Ian_H
It doesn't look like the door has Room Calculation point turned on.
Message 46 of 88
Ian_H
in reply to: ToanDN
It is selected in the family, is there something I need to turn on or select in the model once it's loaded into the project?
Message 47 of 88
in reply to: Ian_H
No.  That is the only box and you already checked it.  So that is not the reason.  Do you have any phases after NEW CONSTRUCTION?  If so, set the Dynamo node the latest Phase and Run.
Edited: can you show the flor plan view of the door family showing the Room Calculation Point arrow?
Message 48 of 88
Ian_H
in reply to: ToanDN
I have tried running it in New Construction and Interior Design and same error
Message 49 of 88
Ian_H
in reply to: ToanDN
Here is the screenshot of the floor plan
Message 50 of 88
in reply to: Ian_H
Looks like everything checked out so I have no more guess.  Share the model if you can.
Message 51 of 88
RDAOU
in reply to: Ian_H
@Ian_H
Pin the Lists under the following node...
  1. What elements are being captured
  2. How many levels are the lists
Message 52 of 88
Ian_H
in reply to: RDAOU
Message 53 of 88
RDAOU
in reply to: Ian_H
@Ian_H
That is your non-pointer ... Empty lists
What phase are the doors
Message 54 of 88
Ian_H
in reply to: RDAOU
The doors that I have updated with the 'Room Calculation Point' selected are all NEW CONSTRUCTION. Is it an all or nothing situation? I only updated 1 type of door in order to test the script.
Message 55 of 88
in reply to: Ian_H
Edit: the below doesn't matter.  It works the same here.
Do you have any shared door families (panel or frame) nested in the door family?
Message 56 of 88
Ian_H
in reply to: ToanDN
Yes, looks like they do
Message 57 of 88
Ian_H
in reply to: ToanDN
ToanDN, PM sent
Message 58 of 88
in reply to: Ian_H
@Ian_H  It works for certain types and not others, some are under the same family .  Maybe it is a starting point to diagnose.
Message 59 of 88
in reply to: Ian_H
@ it works after I have removed any doors that were created and demolished under the same phase.
Message 60 of 88
Ian_H
in reply to: ToanDN
Awesome! Thank you so much helping me out with this!
Forma Design Contest
Technology Administrators
