Hello I would like to create a twisted form ( see picture ) for a gate.
I tried the Swept blend tool but it doesn't work that well. Which tool is the best to create something like this?
THank you !!
Solved by Avaris.. Go to Solution.
Why does the swept blend/extrusion not work? You can make it in two parts and join?
Otherwise try the massing environment and make a loft. (Wouldn't recommend it for this simple gate).
I don't know why, but for me only a 45 degree twist works for me.
90 degrees will result in a simple blended extrusion.
Maybe someone else does know how to do 90 degrees?
See attached family. Join multiple of them to create one louvre.
you can do it using a simple mass extrusion and then rotate upper shape...
Constantin Stroescu
