Place a door in a louvered cutain wall?
5 ANTWORTEN 5
Nachricht 1 von 6
emmanuelbee
890 Aufrufe, 5 Antworten
How can I place a normal door in the attached louvered wall? any suggestions?
5 ANTWORTEN 5
Nachricht 2 von 6
Ilic.Andrej
als Antwort auf: emmanuelbee
You need to create a curtain door panel. Then select the curtain panel which you want to replace, unpin it and select the door using type selector.
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
Nachricht 3 von 6
emmanuelbee
als Antwort auf: Ilic.Andrej
The problem that I'm having is I dont know how to cut an outline of the door size within the panel.
Nachricht 4 von 6
Ilic.Andrej
Curtain wall grids determine the size of the panel/door....
Andrej Ilić
MSc Arch
Nachricht 5 von 6
emmanuelbee
yes exactly but with all the louvers in the way, its difficult to use the curtain grids to create a door panel outline
Nachricht 6 von 6
Ilic.Andrej
Select the grid line and use "add/remove segments".
Andrej Ilić
MSc Arch
