Create twisted plane
5 REPLIES 5
1512 Views, 5 Replies
Hello I would like to create a twisted form ( see picture ) for a gate.
I tried the Swept blend tool but it doesn't work that well. Which tool is the best to create something like this?
THank you !!
5 REPLIES 5
Avaris.
Why does the swept blend/extrusion not work? You can make it in two parts and join?
Otherwise try the massing environment and make a loft. (Wouldn't recommend it for this simple gate).
Avaris.
in reply to: Avaris.
I don't know why, but for me only a 45 degree twist works for me.
90 degrees will result in a simple blended extrusion.
Maybe someone else does know how to do 90 degrees?
See attached family. Join multiple of them to create one louvre.
constantin.stroescu
you can do it using a simple mass extrusion and then rotate upper shape...
Constantin Stroescu
constantin.stroescu
another way of doing this with Mass using Levels...
Constantin Stroescu
I used the massing environment like you said, this one works
thank you
Forma Design Contest
Technology Administrators
