Hi all, I'm learning how to use ilogic for inventor.
My current issue that I can't seem to get around is a syntax error.
I have obtained the correct syntax from the Autodesk website I need to use but I can't see where I am entering it incorrectly.
I am using assembly, with various iparts
I have a user parameter I named "Tank_Type_STANDARD" which I want to control the factory ipart that is loaded to the assembly. the goal is to create a form that can produce different variations of an assembly through basic changes made to the form.
my failing rule is as follows:
If Tank_Type_STANDARD = 1
Then iPart.ChangeRow("Tank_wall_base", "Tank_Lower_Section_01")
ElseIf Tank_Type_STANDARD = 2
Then iPart.ChangeRow("Tank_wall_base", "Tank_Lower_Section_02")
End If
Have I approached this problem incorrectly? can my goal be achieved? I will continue to try and solve this problem in the meantime. Any and all assistance is greatly appreciated.
regards,
Chris
Hello Chris,
It seems there are many posts shows how to handle it -
https://forums.autodesk.com/t5/inventor-customization/change-ipart-member-with-ilogic/td-p/6219938
https://forums.autodesk.com/t5/inventor-customization/change-ipart-member-with-ilogic/td-p/7453039
https://forums.autodesk.com/t5/inventor-forum/changing-ipart-with-ilogic/td-p/6370599
Hope those helps!
Several hours in and I can't see where these suggestions relate or how to apply them. Everything I try comes back with syntax errors or does nothing.
This should be a pretty basic function, or I'm going about it the wrong way. I just want to change an ipart in assembly without manually doing so in the assembly tree.
thanks
Edit*
Not sure if part name is stabilized so will try this now
FTFY
Structure is important in coding. The 'then' needs to be at the end of the line (or not exist at all in some programming languages)
If Tank_Type_STANDARD = 1 Then iPart.ChangeRow("Tank_wall_base", "Tank_Lower_Section_01") ElseIf Tank_Type_STANDARD = 2 Then iPart.ChangeRow("Tank_wall_base", "Tank_Lower_Section_02") End If
Like this?
If Tank_Type_STANDARD = 3 Then iPart.ChangeRow("Tank_Lower_Section", "T03") Else If Tank_Type_STANDARD = 4 Then iPart.ChangeRow("Tank_Lower_Section", "T04") End If
i get a syntax error on line 2 & 4 still whereas placing "then" at the "end" of line 1 & 2 produces no error.
thanks
Okay thanks that got me a step further, now i just have to figure out why it isn't finding the row.
I get this message:
"Error in rule: "rule", in document: "Assembly.iam"
iPart.ChangeRow: No iPart row with the specification "anthing i enter here" was found in the component "ipart".
when it refers to the row do I enter the member name, the part number or the number to the far left of the table?
thanks
Yeah, could be it!
Simply trying things out and seeing what happens will probably get your results a lot faster than posting back to the forums every time.
Sounds like a reasonable assumption that it could be looking for information in the first column of the iPart table.
Or maybe the format of the table is off too.
You could always review the documentation in the help files about iPart iLogic too.
