04-09-2018
08:55 PM
- Mute
- Permalink
- Report
04-09-2018
08:55 PM
FTFY
Structure is important in coding. The 'then' needs to be at the end of the line (or not exist at all in some programming languages)
If Tank_Type_STANDARD = 1 Then
iPart.ChangeRow("Tank_wall_base", "Tank_Lower_Section_01")
ElseIf Tank_Type_STANDARD = 2 Then
iPart.ChangeRow("Tank_wall_base", "Tank_Lower_Section_02")
End If
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
