Change iPart member with iLogic
karthur1
Mentor Mentor
Message 1 of 13
karthur1
I have a subassembly that is made up of several parts (4 or 5 actually).  All the parts are from the same parent, just a different length.  I have my iPart table setup where I can just choose the length that I want (within .25in increments).  The sub assembly is put together and then I will cut the end at an angle with an extrude cut at the assembly level. It will look like this when it is finished.  I do this so that I can get an accutate parts list of the lengths that I need.
If I want to make a new sub assembly, I just copy this one, and then change the length of each member to what I need.  It is easy to do... just really time consuming.  I would like to be able to enter an amount and then iLogic would step thru the assembly, open each ipart memeber and then change the length to the appropriate ipart member based on the new length.
I this something that could be done with iLogic?
Kirk
Replies (12)
Message 2 of 13
Curtis_Waguespack
Hi karthur1,
Here's a real quick example that might or might not be what you're after.
I hope this helps.
Curtis
'ipart member names and values
'Part1-01 = 12"
'Part1-02 = 15"
'Part1-03 = 18"
oLength = InputBox("Enter a length.", "iLogic", "12")
'assembly browser names are:
'Part1
'Part2
'Part3
If oLength <= 12 Then
'change ipart to row 1
iPart.ChangeRow("Part1", "Part1-01")
iPart.ChangeRow("Part2", "Part1-01")
iPart.ChangeRow("Part3", "Part1-01")
ElseIf oLength >= 18 Then
'change ipart to row 3
iPart.ChangeRow("Part1", "Part1-03")
iPart.ChangeRow("Part2", "Part1-03")
iPart.ChangeRow("Part3", "Part1-03")
Else 'between 12 and 18
'change ipart to row 2
iPart.ChangeRow("Part1", "Part1-02")
iPart.ChangeRow("Part2", "Part1-02")
iPart.ChangeRow("Part3", "Part1-02")
Message 3 of 13
karthur1
I don't really know what row the new length will be in the ipart... I just know how much I want to change the length by.  The length is a "key" in the ipart
How will the macro search the table and find the correct row or is that even necessary since the length is a key for the ipart?
Kirk
Message 4 of 13
Curtis_Waguespack
Hi karthur1,
I might still be missing the mark, but this example finds the value for the length (d2) in the ipart table that matches the input.
I hope this helps.
Curtis
'ipart row / member names and values
'Part1-01 = 12"
'Part1-02 = 15"
'Part1-03 = 18"
'Part1
'Part2
'Part3
'd2 is the length column in the iPart factory
'syntax example
'oRow = iPart.FindRow("iComponentName:1", "columnName", "<=", 0.2, "columnName", "<=", 4.1)
oRow = iPart.FindRow("Part1", "d2", "=", oLength)
iPart.FindRow("Part2", "d2", "=", oLength)
iPart.FindRow("Part3", "d2", "=", oLength)
If oRow < 0 Then
MessageBox.Show("No matching row found in iPart.", "iLogic")
Else
MessageBox.Show("iPart set to row: " & oRow , "iLogic")
Message 5 of 13
karthur1
That gives me some ideas on how I might can make it work.
It will have to do this:
ask for change amount
go to each part in the assembly and get the name of it
find the row for the current length
find the row with the "current length + change mount"
Set the member to this new row
Go to next part in assembly and do the above steps
Stop when the members have been changed.
Can you tell me  the signifigance of the "o" prefix on the variable name, i.e. oLength, oRow?  I really need to learn how to program more in iLogic.
Kirk
Message 6 of 13
Curtis_Waguespack
Hi karthur1,
There really isn't any. Generally speaking variables are often named such as shown below, with the first letters indicating the varible type.
srtTest ( a String )
intTest ( an Integer )
lngTest ( a Long )
objTest ( an Object )
see this link for more: https://msdn.microsoft.com/en-us/library/aa240858(v=vs.60).aspx
But I picked up the habit of just naming everything with an o, from this forum. I ran across a thread on here where one of the Autodesk employees confessed to starting the oName trend years and years ago, but I forget who it was.
The main thing the prefix does, is it helps you know that it's a constant or variable when you're reading through the code.
I'm sure using oName for everything annoys some people, but it's never caused me any grief.
Note too there are some other iPart related snippets that you might look into.
You access the available snippets from the Snippets area of the Edit Rule dialog box:
If you click those snippets it'll add them to your rule, and then you can search this forum for related examples too.
I hope this helps.
Curtis
Message 7 of 13
karthur1
Curtis,
I was able to play around with the code and figure it out.  I can get it to change the member like I want if I pick it.  I would like for it to automatically cycle thru the assembly and change each ipart member by the amount that I entered.
My iPart table uses the "Size" and "Length" keys to select the member.
I am sure I need a for/Next loop, but not quite sure how to make it work.
Kirk
Dim comp = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyOccurrenceFilter,"Select Component to change:")
'MsgBox(comp.Name)
'DefaultRowNumber = iPart.RowNumber(comp.Name)
'rowstringvalue=iPart.CurrentRowStringValue("Member")
'rowstringvalue=iPart.CurrentRowStringValue("Length")
oLength = InputBox("Enter the length change.", "iLogic", "0")
rowName = iPart.RowName(comp.Name)
RowValue=iPart.CurrentRowValue("Length")
SizeStringValue=iPart.CurrentRowStringValue("Size")
NewLength=RowValue+oLength
MsgBox("Size==>  " & SizeStringValue & "   RowName==> " & rowName & "   New Length ==>  "& NewLength)
'syntax example
i = iPart.FindRow(comp.Name, "Size", "<=",SizeStringValue , "Length", "<=", NewLength)
Message 8 of 13
Curtis_Waguespack
Hi karthur1,
I was hoping to get back to this today, but I've run out of time.
I think you're right, you'll want to loop through the assembly and look for iparts, see this example for some code to determine if a part is an iPart:
https://forums.autodesk.com/t5/inventor-customization/ilogic-test-for-ipart/m-p/3761988#M42030
I hope this helps.
Curtis
Message 9 of 13
karthur1
I got my "Test" assembly to work, but when I moved over to my actual model, it did not.  I think probably the reason its not working is because the iparts in my "test" ipart only has one key.... the iparts in my working model actually has two keys for the iparts.
In my working model, the ipart has the keys "Member" and "Cutlength".  My iLogic command looks something like this:
MemberStringValue=iPart.CurrentRowStringValue("Member")
i = iPart.FindRow(comp.Name, "Member", "=",MemberStringValue , "Cutlength", "=", NewLength)
MsgBox (i)
When I run this code, the member does not change.  Can you explain what the command is actually looking for in order for the conditions to be satisfied?  The last line will print "i" in the FindRow command.  It reports "-1".  From what I have read that means the condition was not met.
Kirk
Message 10 of 13
karthur1
I am a little closer.  I can now select a ipart and enter a "New" length and it will change to the new length.  This is much better than having to select it from the ipart tables.  However, I would like to enter a length and the iLogic code would then change ALL the members in the subassembly.
I know all the members in the sub are iparts, so no real need to check for that.
Here is what I have got so far:
'MsgBox(comp.Name)
oLength = InputBox("Enter the length change (+ or -).", "iLogic", "0")
RowValue=iPart.CurrentRowValue("Cutlength")
StockNoStringValue=iPart.CurrentRowStringValue("Stock Number")
MemberStringValue=StockNoStringValue & "-" & NewLength
'MsgBox("Size==> " & MemberStringValue & " RowName==> " & rowName & " New Length ==> "& NewLength)
'syntax example
i = iPart.FindRow(comp.Name, "Member", "=<", MemberStringValue) 'This will change the row To the new length
If i < 0 Then
'Else
'MessageBox.Show("iPart set to row: " & oRow , "iLogic")
How do I make it cycle thru to each ipart and change it based on the "New" length?
Message 11 of 13
wayne.brill
Here is an example I used to test. It uses a for loop to change the row of each of the iParts in the assembly. My iParts where very simple but it does change all of them.  This example is getting a value of a Length parameter and using that to change the row of the iPart. (in my iPart the values could be 1.0 in, 2.0 in, or 3.0 in)
You may have to add some test in your code to run different code based on which occurrence the code is going to change.
oLength = InputBox("Enter the Length parameter", "iLogic", "3.0 in")
Dim oAsmDoc as Inventor.AssemblyDocument
oAsmDoc = ThisDoc.Document
Dim comp As Inventor.ComponentOccurrence
For Each comp In oAsmDoc.ComponentDefinition.Occurrences
    i = iPart.FindRow(comp.Name, "Length", "=", oLength)
    If i < 0 Then
        MessageBox.Show("Some problem occurred", "iLogic")
    Else
        MessageBox.Show("iPart set to row: " & oLength , "iLogic")
Next
Wayne
Wayne Brill
Developer Technical Services
Autodesk Developer Network
Message 12 of 13
karthur1
Wayne,
I was able to change the variables to work with my iparts and that works great!  So much easier than selecting one-at-time.
Kirk
Message 13 of 13
forbillian
Wayne.
Exactly what I needed to help me find certain iPart members in an assembly by row name to change the BOM status to reference.
I have a sub assembly which features many possible ipart Bolts & locations - some of which turn on & off depending on rules but I need to ensure the Bolts that are set to reference only have a reference BOM status
Thankyou so much Wayne:
SyntaxEditor Code Snippet
If iPart.RowName(comp.Name) = "BOLT_NUT_ASM_REFERENCE" Then
        comp.Definition.BOMStructure = 51972 'Reference
    Else
        comp.Definition.BOMStructure = 51973 'Purchased
Next
