Hi
I have been trying to create a printing rule, I print half size (Scale 0.5) to hard copy printer and full size (Scale 1:1) to PDF.
At this stage I am still with the Hard copy printer and I am unable to set the custom scale.
I have used existing code found on the forum, and have been trying to adjust it to suit my requirements.
As you can see I have tried various options of changing the scale, but regardless it still prints to fit. (I commented out the scale to fit)
Hopefully it's just a syntax error?
Existing code:
Dim oDrawDoc As Document oDrawDoc = ThisApplication.ActiveDocument Dim oPrintMgr As PrintManager oPrintMgr = oDrawDoc.PrintManager 'specify your printer name oPrintMgr.Printer = "Canon iR2520 UFRII LT" oPrintMgr.ColorMode = kPrintDefaultColorMode oPrintMgr.Orientation = kLandscapeOrientation oPrintMgr.PaperSize = PaperSizeEnum.kPaperSizeA3 oPrintMgr.Scalemode = kCustomScale oPrintMgr.ScaleMode = PrintScaleModeEnum.kPrintBestFitScale ''Testing for scale 'oPrintMgr.Scale = 0.5 '.Scale = 0.5 'oPrintMgr.ScaleMode = PrintScaleModeEnum.scale=0.5 oPrintMgr.SubmitPrint
Thanks guys.
Hopefully the PDF print is easier, as its a 1:1 print.
Reg
2026.3
2026.3
