Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
How to change Balloon Style?
3 REPLIES 3
dg2405
806 Views, 3 Replies
how can i change a balloon style to another one?
3 REPLIES 3
petestrycharske
in reply to: dg2405
dg2405,
Good afternoon!  Not completely sure if this is what you're after, but here is a short video illustrating how to switch from one balloon style to another.  Hope this helps and have a most blessed day!
Peace,
Pete
Just a guy on a couch...
Please give a kudos if helpful and mark as a solution if somehow I got it right.
salariua
in reply to: dg2405
You can either change all balloons, or prompt the users for the ones to change.
prompt for user selection
While True
	Try
		' Get balloon from user selection
		Dim oBalloon As Balloon
		oBalloon = ThisApplication.CommandManager.Pick( _
				SelectionFilterEnum.kDrawingBalloonFilter, "Pick a baloon")
		If oBalloon Is Nothing Then
			MessageBox.Show ("Selection was cancelled","ilogic")
			Beep
			Exit While
End While
Change all balloons on all sheets
' Set a reference to the drawing document.
' This assumes a drawing document is active.
Dim oDrawDoc As DrawingDocument
oDrawDoc = ThisApplication.ActiveDocument
Dim oStyles As DrawingStylesManager
oStyles = oDrawDoc.StylesManager
'process all sheets
For Each oSheets In oDrawDoc.Sheets
	' Iterate over each balloon on the sheet.
	For Each oBalloon In oActiveSheet.Balloons
	'replace "Tags" to your style name
	oBalloon.Style = oStyles.BalloonStyles.item("Tags")
	Next
Next
Good Luck
Adrian S.
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
salariua
in reply to: salariua
It has come to my attention that the iLogic code I have posted before is wrong and not working.
Here is the corrected version:
Dim oSheet As Sheet
For Each oSheet In oDrawDoc.Sheets
	For Each oBalloon In oSheet.Balloons
		oBalloon.Style = oStyles.BalloonStyles.Item("Tag")
	Next
Next
Adrian S.
blog.ads-sol.com
Technology Administrators
