dg2405,
Good afternoon! Not completely sure if this is what you're after, but here is a short video illustrating how to switch from one balloon style to another. Hope this helps and have a most blessed day!
You can either change all balloons, or prompt the users for the ones to change.
prompt for user selection
While True
Try
' Get balloon from user selection
Dim oBalloon As Balloon
oBalloon = ThisApplication.CommandManager.Pick( _
SelectionFilterEnum.kDrawingBalloonFilter, "Pick a baloon")
If oBalloon Is Nothing Then
MessageBox.Show ("Selection was cancelled","ilogic")
Beep
Exit While
End If
End While
Change all balloons on all sheets
' Set a reference to the drawing document.
' This assumes a drawing document is active.
Dim oDrawDoc As DrawingDocument
oDrawDoc = ThisApplication.ActiveDocument
Dim oStyles As DrawingStylesManager
oStyles = oDrawDoc.StylesManager
'process all sheets
For Each oSheets In oDrawDoc.Sheets
' Iterate over each balloon on the sheet.
For Each oBalloon In oActiveSheet.Balloons
'replace "Tags" to your style name
oBalloon.Style = oStyles.BalloonStyles.item("Tags")
Next
Next
Good Luck
It has come to my attention that the iLogic code I have posted before is wrong and not working.
Here is the corrected version:
Dim oSheet As Sheet
For Each oSheet In oDrawDoc.Sheets
For Each oBalloon In oSheet.Balloons
oBalloon.Style = oStyles.BalloonStyles.Item("Tag")
Next
Next
