Can't call the function to get the tight bounding box
11 REPLIES 11
Message 1 of 12
ngocson8335
968 Views, 11 Replies
Dear Experts,
Please help me to fix the problem, I can't call the function to get the tight bounding box by VBA.Net. I'm using the Microsoft studio to coding.
How can I fix this problem?
Thank you so much.
Ngoc Son
Inventor's user
Ngoc Son
Autodesk User
11 REPLIES 11
Message 2 of 12
How does the function look like?
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Message 3 of 12
It looks like:
Imports System
Imports System.Runtime.InteropServices
Imports Inventor
Public Class Form1
Dim invApp As Inventor.Application
Dim partDoc As Inventor.PartDocument
Private Sub Form1_Load(sender As Object, e As EventArgs) Handles MyBase.Load
invApp = Marshal.GetActiveObject("Inventor.Application")
End Sub
Private Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.Click
partDoc = invApp.ActiveDocument
Dim body As SurfaceBody
body = invApp.CommandManager.Pick(SelectionFilterEnum.kPartBodyFilter, "Select the body.")
Dim bndBox As Box = calculateTightBoundingBox(body)
Dim sk As Sketch3D = partDoc.ComponentDefinition.Sketches3D.Add()
Dim lines As SketchLines3D = sk.SketchLines3D
Dim tg As TransientGeometry = invApp.TransientGeometry
Dim minXYZ As Point = bndBox.MinPoint
Dim minXYmaxZ As Point = tg.CreatePoint(bndBox.MinPoint.X, bndBox.MinPoint.Y, bndBox.MaxPoint.Z)
Dim minXmaxYZ As Point = tg.CreatePoint(bndBox.MinPoint.X, bndBox.MaxPoint.Y, bndBox.MaxPoint.Z)
Dim minXZmaxY As Point = tg.CreatePoint(bndBox.MinPoint.X, bndBox.MaxPoint.Y, bndBox.MinPoint.Z)
Dim maxXYZ As Point = bndBox.MaxPoint
Dim maxXYminZ As Point = tg.CreatePoint(bndBox.MaxPoint.X, bndBox.MaxPoint.Y, bndBox.MinPoint.Z)
Dim maxXZminY As Point = tg.CreatePoint(bndBox.MaxPoint.X, bndBox.MinPoint.Y, bndBox.MaxPoint.Z)
Dim maxXminYZ As Point = tg.CreatePoint(bndBox.MaxPoint.X, bndBox.MinPoint.Y, bndBox.MinPoint.Z)
lines.AddByTwoPoints(minXYZ, minXYmaxZ)
lines.AddByTwoPoints(minXYZ, minXZmaxY)
lines.AddByTwoPoints(minXZmaxY, minXmaxYZ)
lines.AddByTwoPoints(minXYmaxZ, minXmaxYZ)
lines.AddByTwoPoints(maxXYZ, maxXYminZ)
lines.AddByTwoPoints(maxXYZ, maxXZminY)
lines.AddByTwoPoints(maxXYminZ, maxXminYZ)
lines.AddByTwoPoints(maxXZminY, maxXminYZ)
lines.AddByTwoPoints(minXYZ, maxXminYZ)
lines.AddByTwoPoints(minXYmaxZ, maxXZminY)
lines.AddByTwoPoints(minXmaxYZ, maxXYZ)
lines.AddByTwoPoints(minXZmaxY, maxXYminZ)
End Sub
End Class
Ngoc Son
Autodesk User
Message 4 of 12
I mean how does the function or module "calculateTightBoundingBox" look like
Arthur Knoors
Message 5 of 12
use this instead because you function is missing...
Public Sub TestTightBoundingBox()
    Dim invApp As Inventor.Application = GetObject(, "Inventor.Application")
    ' Have a body selected.
    ' Call the function to get the tight bounding box.
    ' Draw the bounding box using a 3D sketch.
    Dim partDoc As PartDocument = invApp.ActiveDocument
End Sub
' Calculates a tight bounding box around the input body.  An optional
' tolerance argument is available.  This specificies the tolerance in
' centimeters.  If not provided the best existing display mesh is used.
Public Function calculateTightBoundingBox(body As SurfaceBody, Optional Tolerance As Double = 0) As Box
    Try
        Dim vertCount As Integer
        Dim facetCount As Integer
        Dim vertCoords() As Double = {}
        Dim normVectors() As Double = {}
        Dim vertInds() As Integer = {}
        ' If the tolerance is zero, use the best display mesh available.
        If Tolerance <= 0 Then
            ' Get the best display mesh available.
            Dim tolCount As Long
            Dim tols() As Double = {}
            Call body.GetExistingFacetTolerances(tolCount, tols)
            Dim bestTol As Double
            bestTol = tols(0)
            For i As Integer = 1 To tolCount - 1
                If tols(i) < bestTol Then
                    bestTol = tols(i)
                End If
            Next
            body.GetExistingFacets(bestTol, vertCount, facetCount, vertCoords, normVectors, vertInds)
        Else
            ' Calculate a new mesh based on the input tolerance.
            body.CalculateFacets(Tolerance, vertCount, facetCount, vertCoords, normVectors, vertInds)
        End If
        Dim tg As TransientGeometry = body.Application.TransientGeometry
        ' Calculate the range of the mesh.
        Dim smallPnt As Point = tg.CreatePoint(vertCoords(0), vertCoords(1), vertCoords(2))
        Dim largePnt As Point = tg.CreatePoint(vertCoords(0), vertCoords(1), vertCoords(2))
        For i As Integer = 1 To vertCount - 1
            Dim vertX As Double = vertCoords(i * 3)
            Dim vertY As Double = vertCoords(i * 3 + 1)
            Dim vertZ As Double = vertCoords(i * 3 + 2)
            If vertX < smallPnt.X Then
                smallPnt.X = vertX
            End If
            If vertY < smallPnt.Y Then
                smallPnt.Y = vertY
            End If
            If vertZ < smallPnt.Z Then
                smallPnt.Z = vertZ
            End If
            If vertX > largePnt.X Then
                largePnt.X = vertX
            End If
            If vertY > largePnt.Y Then
                largePnt.Y = vertY
            End If
            If vertZ > largePnt.Z Then
                largePnt.Z = vertZ
            End If
        Next
        ' Create and return a Box as the result.
        Dim newBox As Box = tg.CreateBox()
        newBox.MinPoint = smallPnt
        newBox.MaxPoint = largePnt
        Return newBox
    Catch ex As Exception
        Return Nothing
    End Try
End Function
Arthur Knoors
Message 6 of 12
Thank you so much
Ngoc Son
Autodesk User
Message 7 of 12
ngocson8335
in reply to: ngocson8335
So I saw the code to use
 ExtentsWidth
ExtentsLength
ExtentsHeight
to create a stock size for a part
SyntaxEditor Code Snippet (ilogic)
		Thickness = Measure.ExtentsLength
		If Measure.ExtentsWidth > Measure.ExtentsLength Then
			Width = Measure.ExtentsWidth
		Else
			Thickness = Measure.ExtentsWidth
			Width = Measure.ExtentsLength
		End If
		If Measure.ExtentsHeight > Width Then
			Lenght = Measure.ExtentsHeight
		Else
			If Measure.ExtentsHeight > Thickness Then
				Lenght = Width
				Width = Measure.ExtentsHeight
			Else
				Lenght = Width
				Width = Thickness
				Thickness = Measure.ExtentsHeight
			End If
		End If
 How can I use it in Visual Studio? I try but can not! Please help me one more!
Thank you!
Ngoc Son
Autodesk User
Message 8 of 12
For Vb.net:
Public Sub DimensionComponentSimple()
dim ThisApplicationInv As Inventor.Application
Try Dim oInventorDoc As Inventor.Document 'oInventorDoc = ThisApplicationInv.ActiveDocument oInventorDoc = ThisApplicationInv.ActiveEditDocument If oInventorDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Or oInventorDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then Dim b As ComponentDefinition = Nothing If oInventorDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then Dim OinventorDocToBeDim As Inventor.AssemblyDocument OinventorDocToBeDim = oInventorDoc b = OinventorDocToBeDim.ComponentDefinition End If If oInventorDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then Dim OinventorDocToBeDim As Inventor.PartDocument OinventorDocToBeDim = oInventorDoc b = OinventorDocToBeDim.ComponentDefinition 'b = CType(oInventorDoc, Inventor.PartDocument).ComponentDefinition
End If Dim c As Box c = b.RangeBox Dim dmax As Point dmax = c.MaxPoint Dim dmin As Point dmin = c.MinPoint Dim dX As Decimal Dim dY As Decimal Dim dZ As Decimal Dim strLENGTH As Single Dim strWIDTH As Single Dim strTHICKNESS As Single dX = (dmax.X - dmin.X) * 10 dY = (dmax.Y - dmin.Y) * 10 dZ = (dmax.Z - dmin.Z) * 10 dX = Math.Round(dX, DocPrec) dY = Math.Round(dY, DocPrec) dZ = Math.Round(dZ, DocPrec) Try If dX = dY Then 'MsgBox("x") strLENGTH = dX '& " mm" strWIDTH = dY strTHICKNESS = dZ End If If dX = dZ Then strLENGTH = dX '& " mm" strWIDTH = dZ '& " mm" strTHICKNESS = dY End If If dZ = dY Then 'MsgBox("x") strLENGTH = dZ '& " mm" strWIDTH = dY strTHICKNESS = dX End If If dX > dY And dX > dZ Then 'MsgBox "x" strLENGTH = dX If dY > dZ Then strWIDTH = dY strTHICKNESS = dZ Else strWIDTH = dZ strTHICKNESS = dY End If End If Catch ex As Exception End Try If dY > dZ And dY > dX Then 'MsgBox "y" strLENGTH = dY If dZ > dX Then strWIDTH = dZ strTHICKNESS = dX Else strWIDTH = dX strTHICKNESS = dZ End If End If If dZ > dX And dZ > dY Then 'MsgBox "z" strLENGTH = dZ If dX > dY Then strWIDTH = dX strTHICKNESS = dY Else strWIDTH = dY strTHICKNESS = dX End If End If Dim LENGTH As [Property] Dim WIDTH As [Property] Dim THICKNESS As [Property] Dim StockNumber As [Property] Dim RoutineDimensioned As [Property] Dim DimensionDirty As Boolean = False Try LENGTH = oInventorDoc.PropertySets.Item("User Defined Properties").Add("", "LENGTH") If Not LENGTH.Expression = strLENGTH & " mm" Then '(dmax.X - dmin.X) * 10 & " mm" LENGTH.Expression = strLENGTH & " mm" DimensionDirty = True End If Catch ex As Exception LENGTH = oInventorDoc.PropertySets.Item("User Defined Properties").Item("LENGTH") If Not LENGTH.Expression = strLENGTH & " mm" Then '(dmax.X - dmin.X) * 10 & " mm" LENGTH.Expression = strLENGTH & " mm" DimensionDirty = True End If End Try Try WIDTH = oInventorDoc.PropertySets.Item("User Defined Properties").Add("", "WIDTH") If Not WIDTH.Expression = strWIDTH & " mm" Then '(dmax.Y - dmin.Y) * 10 & " mm" WIDTH.Expression = strWIDTH & " mm" DimensionDirty = True End If Catch ex As Exception WIDTH = oInventorDoc.PropertySets.Item("User Defined Properties").Item("WIDTH") If Not WIDTH.Expression = strWIDTH & " mm" Then '(dmax.Y - dmin.Y) * 10 & " mm" WIDTH.Expression = strWIDTH & " mm" DimensionDirty = True End If End Try Try THICKNESS = oInventorDoc.PropertySets.Item("User Defined Properties").Add("", "THICKNESS") If Not THICKNESS.Expression = strTHICKNESS & " mm" Then '(dmax.z - dmin.z) * 10 & " mm" THICKNESS.Expression = strTHICKNESS & " mm" DimensionDirty = True End If Catch ex As Exception THICKNESS = oInventorDoc.PropertySets.Item("User Defined Properties").Item("THICKNESS") If Not THICKNESS.Expression = strTHICKNESS & " mm" Then '(dmax.z - dmin.z) * 10 & " mm" THICKNESS.Expression = strTHICKNESS & " mm" DimensionDirty = True End If End Try Try StockNumber = oInventorDoc.PropertySets.Item("Design Tracking Properties").Item("Stock Number") If Not StockNumber.Expression = "=<Width> x <Thickness>" Then StockNumber.Expression = "=<Width> x <Thickness>" End If Catch ex As Exception MsgBox("Stock Number Error: " & ex.Message) End Try 'Only show message if needed on dirty property If oInventorDoc.Dirty = True Then If DimensionDirty = True Then msgbox = "Dimensions of " & oInventorDoc.DisplayName & " :" & LENGTH.Expression & " x " & WIDTH.Expression & " x " & THICKNESS.Expression End If End If End If Catch ex As Exception MsgBox("Error Dimensioning: " & ex.Message) End Try End Sub
Arthur Knoors
Message 9 of 12
Hi Bradeneurope,
Thank you for your help.
Manymany Thanks!
Ngoc Son
Autodesk User
Message 10 of 12
ngocson8335
Hi Bradeneurope,
Please help me. Now I can calculate the stock number for parts in the context Assembly. But I have a problem is I can not finish edit part in assembly by code.
Can you suggest me another way that no need to edit part in the context ass, please?
Here is the code:
Imports System
Imports Inventor
Public Class Form1
Dim assemblyDoc As Inventor.AssemblyDocument
assemblyDoc = invApp.ActiveEditDocument
Dim assemblyDef As Inventor.AssemblyComponentDefinition
assemblyDef = assemblyDoc.ComponentDefinition
Dim oComponentOccurrence As Inventor.ComponentOccurrence
For Each oComponentOccurrence In assemblyDef.Occurrences
Dim oBox As Inventor.Box
oBox = oComponentOccurrence.RangeBox
Dim dmax As Point
dmax = oBox.MaxPoint
Dim dmin As Point
dmin = oBox.MinPoint
Dim dX As Decimal
Dim dY As Decimal
Dim dZ As Decimal
Dim strLength As Single
Dim strWidth As Single
Dim strThickness As Single
Dim docPrec As Integer
dX = Math.Round(dX, docPrec)
dY = Math.Round(dY, docPrec)
dZ = Math.Round(dZ, docPrec)
Try
If dX = dY Then
strLength = dX
strWidth = dY
strThickness = dZ
End If
If dY = dZ Then
strLength = dX
strWidth = dZ
strThickness = dY
End If
If dX = dZ Then
strLength = dZ
strWidth = dY
strThickness = dX
End If
strLength = dX
If dY > dZ Then
strWidth = dY
strThickness = dZ
Else
strWidth = dZ
strThickness = dY
End If
End If
End Try
If dY > dX And dY > dZ Then
strLength = dY
If dX > dZ Then
strWidth = dX
strThickness = dZ
Else
strWidth = dZ
strThickness = dX
End If
End If
strLength = dZ
If dX > dY Then
strWidth = dX
strThickness = dY
Else
strWidth = dY
strThickness = dX
End If
End If
MsgBox("Stock Number of " & oComponentOccurrence.Name & "is: " & strLength & " mm x " & strWidth & " mm x " & strThickness & " mm")
oComponentOccurrence.Edit()
Dim length As [Property]
Dim dimensiondirty As Boolean = False
partDoc = invApp.ActiveEditDocument
Try
length = partDoc.PropertySets.Item("User Defined Properties").Add("", "Length")
If Not length.Expression = strLength & " mm" Then
dimensiondirty = True
End If
length = partDoc.PropertySets.Item("User Defined Properties").Item("Length")
End If
End Try
Next
End Sub
End Sub
End Class
Thank you so much
Ngoc Son
Inventor's User
Ngoc Son
Autodesk User
Message 11 of 12
Hello. I am new to the subject of Inventor VBA programming, and I also do not understand how to make the "calcualteTightBoundingBox(Body)"  in the following code
(source: https://modthemachine.typepad.com/my_weblog/2017/06/getting-the-overall-size-of-parts.html) :
    Set body = ThisApplication.CommandManager.Pick(kPartBodyFilter, "Select the body.")
    Dim bndBox As Box
    Set bndBox = calculateTightBoundingBox(body)
    Set partDoc = ThisApplication.ActiveDocument
    Dim sk As Sketch3D
    Set sk = partDoc.ComponentDefinition.Sketches3D.Add()
    Set lines = sk.SketchLines3D
    Set tg = ThisApplication.TransientGeometry
    Dim minXYZ As Point
    Set minXYZ = bndBox.MinPoint
    Set minXYmaxZ = tg.CreatePoint(bndBox.MinPoint.x, bndBox.MinPoint.y, bndBox.MaxPoint.Z)
    Set minXmaxYZ = tg.CreatePoint(bndBox.MinPoint.x, bndBox.MaxPoint.y, bndBox.MaxPoint.Z)
    Set minXZmaxY = tg.CreatePoint(bndBox.MinPoint.x, bndBox.MaxPoint.y, bndBox.MinPoint.Z)
    Dim maxXYZ As Point
    Set maxXYZ = bndBox.MaxPoint
    Set maxXYminZ = tg.CreatePoint(bndBox.MaxPoint.x, bndBox.MaxPoint.y, bndBox.MinPoint.Z)
    Set maxXZminY = tg.CreatePoint(bndBox.MaxPoint.x, bndBox.MinPoint.y, bndBox.MaxPoint.Z)
    Set maxXminYZ = tg.CreatePoint(bndBox.MaxPoint.x, bndBox.MinPoint.y, bndBox.MinPoint.Z)
    Call lines.AddByTwoPoints(minXYZ, minXYmaxZ)
    Call lines.AddByTwoPoints(minXYZ, minXZmaxY)
    Call lines.AddByTwoPoints(minXZmaxY, minXmaxYZ)
    Call lines.AddByTwoPoints(minXYmaxZ, minXmaxYZ)
    Call lines.AddByTwoPoints(maxXYZ, maxXYminZ)
    Call lines.AddByTwoPoints(maxXYZ, maxXZminY)
    Call lines.AddByTwoPoints(maxXYminZ, maxXminYZ)
    Call lines.AddByTwoPoints(maxXZminY, maxXminYZ)
    Call lines.AddByTwoPoints(minXYZ, maxXminYZ)
    Call lines.AddByTwoPoints(minXYmaxZ, maxXZminY)
    Call lines.AddByTwoPoints(minXmaxYZ, maxXYZ)
    Call lines.AddByTwoPoints(minXZmaxY, maxXYminZ)
End Sub
Message 12 of 12
Ralf_Krieg
Hello
There are the codetags missing around the function, so it looks a little confusing. The complete VBA Code is
    Dim bndBox As Box
    Dim sk As Sketch3D
    Dim minXYZ As Point
    Dim maxXYZ As Point
End Sub
    On Error GoTo ErrorFound
    Dim vertCount As Long
    Dim facetCount As Long
    Dim vertInds() As Long
        Dim i As Integer
        bestTol = tols(0)
        For i = 1 To tolCount - 1
                bestTol = tols(i)
            End If
        Next
        Call body.GetExistingFacets(bestTol, vertCount, facetCount, vertCoords, normVectors, vertInds)
    Else
        Call body.CalculateFacets(Tolerance, vertCount, facetCount, vertCoords, normVectors, vertInds)
    End If
    Set smallPnt = tg.CreatePoint(vertCoords(0), vertCoords(1), vertCoords(2))
    Set largePnt = tg.CreatePoint(vertCoords(0), vertCoords(1), vertCoords(2))
    For i = 1 To vertCount - 1
        Dim vertX As Double
        Dim vertY As Double
        Dim vertZ As Double
        vertX = vertCoords(i * 3)
        vertY = vertCoords(i * 3 + 1)
        vertZ = vertCoords(i * 3 + 2)
        If vertX < smallPnt.x Then
            smallPnt.x = vertX
        End If
        If vertY < smallPnt.y Then
            smallPnt.y = vertY
        End If
            smallPnt.Z = vertZ
        End If
        If vertX > largePnt.x Then
            largePnt.x = vertX
        End If
        If vertY > largePnt.y Then
            largePnt.y = vertY
        End If
            largePnt.Z = vertZ
        End If
    Next
    Set calculateTightBoundingBox = tg.CreateBox()
    calculateTightBoundingBox.MinPoint = smallPnt
    calculateTightBoundingBox.MaxPoint = largePnt
    Exit Function
ErrorFound:
    Set calculateTightBoundingBox = Nothing
    Exit Function
End Function
R. Krieg
RKW Solutions GmbH
www.rkw-solutions.com
Technology Administrators
