use this instead because you function is missing...
Public Sub TestTightBoundingBox()
    Dim invApp As Inventor.Application = GetObject(, "Inventor.Application")
    ' Have a body selected.
    Dim body As SurfaceBody
    body = invApp.CommandManager.Pick(SelectionFilterEnum.kPartBodyFilter, "Select the body.")
    ' Call the function to get the tight bounding box.
    Dim bndBox As Box = calculateTightBoundingBox(body)
    ' Draw the bounding box using a 3D sketch.
    Dim partDoc As PartDocument = invApp.ActiveDocument
    Dim sk As Sketch3D = partDoc.ComponentDefinition.Sketches3D.Add()
    Dim lines As SketchLines3D = sk.SketchLines3D
    Dim tg As TransientGeometry = invApp.TransientGeometry
    Dim minXYZ As Point = bndBox.MinPoint
    Dim minXYmaxZ As Point = tg.CreatePoint(bndBox.MinPoint.X, bndBox.MinPoint.Y, bndBox.MaxPoint.Z)
    Dim minXmaxYZ As Point = tg.CreatePoint(bndBox.MinPoint.X, bndBox.MaxPoint.Y, bndBox.MaxPoint.Z)
    Dim minXZmaxY As Point = tg.CreatePoint(bndBox.MinPoint.X, bndBox.MaxPoint.Y, bndBox.MinPoint.Z)
    Dim maxXYZ As Point = bndBox.MaxPoint
    Dim maxXYminZ As Point = tg.CreatePoint(bndBox.MaxPoint.X, bndBox.MaxPoint.Y, bndBox.MinPoint.Z)
    Dim maxXZminY As Point = tg.CreatePoint(bndBox.MaxPoint.X, bndBox.MinPoint.Y, bndBox.MaxPoint.Z)
    Dim maxXminYZ As Point = tg.CreatePoint(bndBox.MaxPoint.X, bndBox.MinPoint.Y, bndBox.MinPoint.Z)
    lines.AddByTwoPoints(minXYZ, minXYmaxZ)
    lines.AddByTwoPoints(minXYZ, minXZmaxY)
    lines.AddByTwoPoints(minXZmaxY, minXmaxYZ)
    lines.AddByTwoPoints(minXYmaxZ, minXmaxYZ)
    lines.AddByTwoPoints(maxXYZ, maxXYminZ)
    lines.AddByTwoPoints(maxXYZ, maxXZminY)
    lines.AddByTwoPoints(maxXYminZ, maxXminYZ)
    lines.AddByTwoPoints(maxXZminY, maxXminYZ)
    lines.AddByTwoPoints(minXYZ, maxXminYZ)
    lines.AddByTwoPoints(minXYmaxZ, maxXZminY)
    lines.AddByTwoPoints(minXmaxYZ, maxXYZ)
    lines.AddByTwoPoints(minXZmaxY, maxXYminZ)
End Sub
' Calculates a tight bounding box around the input body.  An optional
' tolerance argument is available.  This specificies the tolerance in
' centimeters.  If not provided the best existing display mesh is used.
Public Function calculateTightBoundingBox(body As SurfaceBody, Optional Tolerance As Double = 0) As Box
    Try
        Dim vertCount As Integer
        Dim facetCount As Integer
        Dim vertCoords() As Double = {}
        Dim normVectors() As Double = {}
        Dim vertInds() As Integer = {}
        ' If the tolerance is zero, use the best display mesh available.
        If Tolerance <= 0 Then
            ' Get the best display mesh available.
            Dim tolCount As Long
            Dim tols() As Double = {}
            Call body.GetExistingFacetTolerances(tolCount, tols)
            Dim bestTol As Double
            bestTol = tols(0)
            For i As Integer = 1 To tolCount - 1
                If tols(i) < bestTol Then
                    bestTol = tols(i)
                End If
            Next
            body.GetExistingFacets(bestTol, vertCount, facetCount, vertCoords, normVectors, vertInds)
        Else
            ' Calculate a new mesh based on the input tolerance.
            body.CalculateFacets(Tolerance, vertCount, facetCount, vertCoords, normVectors, vertInds)
        End If
        Dim tg As TransientGeometry = body.Application.TransientGeometry
        ' Calculate the range of the mesh.
        Dim smallPnt As Point = tg.CreatePoint(vertCoords(0), vertCoords(1), vertCoords(2))
        Dim largePnt As Point = tg.CreatePoint(vertCoords(0), vertCoords(1), vertCoords(2))
        For i As Integer = 1 To vertCount - 1
            Dim vertX As Double = vertCoords(i * 3)
            Dim vertY As Double = vertCoords(i * 3 + 1)
            Dim vertZ As Double = vertCoords(i * 3 + 2)
            If vertX < smallPnt.X Then
                smallPnt.X = vertX
            End If
            If vertY < smallPnt.Y Then
                smallPnt.Y = vertY
            End If
            If vertZ < smallPnt.Z Then
                smallPnt.Z = vertZ
            End If
            If vertX > largePnt.X Then
                largePnt.X = vertX
            End If
            If vertY > largePnt.Y Then
                largePnt.Y = vertY
            End If
            If vertZ > largePnt.Z Then
                largePnt.Z = vertZ
            End If
        Next
        ' Create and return a Box as the result.
        Dim newBox As Box = tg.CreateBox()
        newBox.MinPoint = smallPnt
        newBox.MaxPoint = largePnt
        Return newBox
    Catch ex As Exception
        Return Nothing
    End Try
End Function
Arthur Knoors
Autodesk Affiliations:
