- Mute
- Permalink
- Report
Hi Bradeneurope,
Please help me. Now I can calculate the stock number for parts in the context Assembly. But I have a problem is I can not finish edit part in assembly by code.
Can you suggest me another way that no need to edit part in the context ass, please?
Here is the code:
Imports System
Imports System.Runtime.InteropServices
Imports Inventor
Public Class Form1
Dim invApp As Inventor.Application
Dim partDoc As Inventor.PartDocument
Dim assemblyDoc As Inventor.AssemblyDocument
Private Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.Click
invApp = Marshal.GetActiveObject("Inventor.Application")
assemblyDoc = invApp.ActiveEditDocument
Dim assemblyDef As Inventor.AssemblyComponentDefinition
assemblyDef = assemblyDoc.ComponentDefinition
Dim oComponentOccurrence As Inventor.ComponentOccurrence
For Each oComponentOccurrence In assemblyDef.Occurrences
Dim oBox As Inventor.Box
oBox = oComponentOccurrence.RangeBox
Dim dmax As Point
dmax = oBox.MaxPoint
Dim dmin As Point
dmin = oBox.MinPoint
Dim dX As Decimal
Dim dY As Decimal
Dim dZ As Decimal
Dim strLength As Single
Dim strWidth As Single
Dim strThickness As Single
dX = (dmax.X - dmin.X) * 10
dY = (dmax.Y - dmin.Y) * 10
dZ = (dmax.Z - dmin.Z) * 10
Dim docPrec As Integer
dX = Math.Round(dX, docPrec)
dY = Math.Round(dY, docPrec)
dZ = Math.Round(dZ, docPrec)
Try
If dX = dY Then
strLength = dX
strWidth = dY
strThickness = dZ
End If
If dY = dZ Then
strLength = dX
strWidth = dZ
strThickness = dY
End If
If dX = dZ Then
strLength = dZ
strWidth = dY
strThickness = dX
End If
If dX > dY And dX > dZ Then
strLength = dX
If dY > dZ Then
strWidth = dY
strThickness = dZ
Else
strWidth = dZ
strThickness = dY
End If
End If
Catch ex As Exception
End Try
If dY > dX And dY > dZ Then
strLength = dY
If dX > dZ Then
strWidth = dX
strThickness = dZ
Else
strWidth = dZ
strThickness = dX
End If
End If
If dZ > dX And dZ > dY Then
strLength = dZ
If dX > dY Then
strWidth = dX
strThickness = dY
Else
strWidth = dY
strThickness = dX
End If
End If
MsgBox("Stock Number of " & oComponentOccurrence.Name & "is: " & strLength & " mm x " & strWidth & " mm x " & strThickness & " mm")
oComponentOccurrence.Edit()
Dim length As [Property]
Dim dimensiondirty As Boolean = False
partDoc = invApp.ActiveEditDocument
Try
length = partDoc.PropertySets.Item("User Defined Properties").Add("", "Length")
If Not length.Expression = strLength & " mm" Then
dimensiondirty = True
End If
length = partDoc.PropertySets.Item("User Defined Properties").Item("Length")
End If
End Try
Next
End Sub
Private Sub Form1_Load(sender As Object, e As EventArgs) Handles MyBase.Load
End Sub
End Class
Thank you so much
Ngoc Son
Inventor's User
Autodesk User
