Dear Experts,
Please help me to fix the problem, I can't call the function to get the tight bounding box by VBA.Net. I'm using the Microsoft studio to coding.
How can I fix this problem?
Thank you so much.
Ngoc Son
Inventor's user
Solved by bradeneuropeArthur. Go to Solution.
How does the function look like?
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
It looks like:
Imports System
Imports System.Runtime.InteropServices
Imports Inventor
Public Class Form1
Dim invApp As Inventor.Application
Dim partDoc As Inventor.PartDocument
Private Sub Form1_Load(sender As Object, e As EventArgs) Handles MyBase.Load
invApp = Marshal.GetActiveObject("Inventor.Application")
End Sub
Private Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.Click
partDoc = invApp.ActiveDocument
Dim body As SurfaceBody
body = invApp.CommandManager.Pick(SelectionFilterEnum.kPartBodyFilter, "Select the body.")
Dim bndBox As Box = calculateTightBoundingBox(body)
Dim sk As Sketch3D = partDoc.ComponentDefinition.Sketches3D.Add()
Dim lines As SketchLines3D = sk.SketchLines3D
Dim tg As TransientGeometry = invApp.TransientGeometry
Dim minXYZ As Point = bndBox.MinPoint
Dim minXYmaxZ As Point = tg.CreatePoint(bndBox.MinPoint.X, bndBox.MinPoint.Y, bndBox.MaxPoint.Z)
Dim minXmaxYZ As Point = tg.CreatePoint(bndBox.MinPoint.X, bndBox.MaxPoint.Y, bndBox.MaxPoint.Z)
Dim minXZmaxY As Point = tg.CreatePoint(bndBox.MinPoint.X, bndBox.MaxPoint.Y, bndBox.MinPoint.Z)
Dim maxXYZ As Point = bndBox.MaxPoint
Dim maxXYminZ As Point = tg.CreatePoint(bndBox.MaxPoint.X, bndBox.MaxPoint.Y, bndBox.MinPoint.Z)
Dim maxXZminY As Point = tg.CreatePoint(bndBox.MaxPoint.X, bndBox.MinPoint.Y, bndBox.MaxPoint.Z)
Dim maxXminYZ As Point = tg.CreatePoint(bndBox.MaxPoint.X, bndBox.MinPoint.Y, bndBox.MinPoint.Z)
lines.AddByTwoPoints(minXYZ, minXYmaxZ)
lines.AddByTwoPoints(minXYZ, minXZmaxY)
lines.AddByTwoPoints(minXZmaxY, minXmaxYZ)
lines.AddByTwoPoints(minXYmaxZ, minXmaxYZ)
lines.AddByTwoPoints(maxXYZ, maxXYminZ)
lines.AddByTwoPoints(maxXYZ, maxXZminY)
lines.AddByTwoPoints(maxXYminZ, maxXminYZ)
lines.AddByTwoPoints(maxXZminY, maxXminYZ)
lines.AddByTwoPoints(minXYZ, maxXminYZ)
lines.AddByTwoPoints(minXYmaxZ, maxXZminY)
lines.AddByTwoPoints(minXmaxYZ, maxXYZ)
lines.AddByTwoPoints(minXZmaxY, maxXYminZ)
End Sub
End Class
I mean how does the function or module "calculateTightBoundingBox" look like
Arthur Knoors
use this instead because you function is missing...
Public Sub TestTightBoundingBox() Dim invApp As Inventor.Application = GetObject(, "Inventor.Application") ' Have a body selected. Dim body As SurfaceBody body = invApp.CommandManager.Pick(SelectionFilterEnum.kPartBodyFilter, "Select the body.") ' Call the function to get the tight bounding box. Dim bndBox As Box = calculateTightBoundingBox(body) ' Draw the bounding box using a 3D sketch. Dim partDoc As PartDocument = invApp.ActiveDocument Dim sk As Sketch3D = partDoc.ComponentDefinition.Sketches3D.Add() Dim lines As SketchLines3D = sk.SketchLines3D Dim tg As TransientGeometry = invApp.TransientGeometry Dim minXYZ As Point = bndBox.MinPoint Dim minXYmaxZ As Point = tg.CreatePoint(bndBox.MinPoint.X, bndBox.MinPoint.Y, bndBox.MaxPoint.Z) Dim minXmaxYZ As Point = tg.CreatePoint(bndBox.MinPoint.X, bndBox.MaxPoint.Y, bndBox.MaxPoint.Z) Dim minXZmaxY As Point = tg.CreatePoint(bndBox.MinPoint.X, bndBox.MaxPoint.Y, bndBox.MinPoint.Z) Dim maxXYZ As Point = bndBox.MaxPoint Dim maxXYminZ As Point = tg.CreatePoint(bndBox.MaxPoint.X, bndBox.MaxPoint.Y, bndBox.MinPoint.Z) Dim maxXZminY As Point = tg.CreatePoint(bndBox.MaxPoint.X, bndBox.MinPoint.Y, bndBox.MaxPoint.Z) Dim maxXminYZ As Point = tg.CreatePoint(bndBox.MaxPoint.X, bndBox.MinPoint.Y, bndBox.MinPoint.Z) lines.AddByTwoPoints(minXYZ, minXYmaxZ) lines.AddByTwoPoints(minXYZ, minXZmaxY) lines.AddByTwoPoints(minXZmaxY, minXmaxYZ) lines.AddByTwoPoints(minXYmaxZ, minXmaxYZ) lines.AddByTwoPoints(maxXYZ, maxXYminZ) lines.AddByTwoPoints(maxXYZ, maxXZminY) lines.AddByTwoPoints(maxXYminZ, maxXminYZ) lines.AddByTwoPoints(maxXZminY, maxXminYZ) lines.AddByTwoPoints(minXYZ, maxXminYZ) lines.AddByTwoPoints(minXYmaxZ, maxXZminY) lines.AddByTwoPoints(minXmaxYZ, maxXYZ) lines.AddByTwoPoints(minXZmaxY, maxXYminZ) End Sub ' Calculates a tight bounding box around the input body. An optional ' tolerance argument is available. This specificies the tolerance in ' centimeters. If not provided the best existing display mesh is used. Public Function calculateTightBoundingBox(body As SurfaceBody, Optional Tolerance As Double = 0) As Box Try Dim vertCount As Integer Dim facetCount As Integer Dim vertCoords() As Double = {} Dim normVectors() As Double = {} Dim vertInds() As Integer = {} ' If the tolerance is zero, use the best display mesh available. If Tolerance <= 0 Then ' Get the best display mesh available. Dim tolCount As Long Dim tols() As Double = {} Call body.GetExistingFacetTolerances(tolCount, tols) Dim bestTol As Double bestTol = tols(0) For i As Integer = 1 To tolCount - 1 If tols(i) < bestTol Then bestTol = tols(i) End If Next body.GetExistingFacets(bestTol, vertCount, facetCount, vertCoords, normVectors, vertInds) Else ' Calculate a new mesh based on the input tolerance. body.CalculateFacets(Tolerance, vertCount, facetCount, vertCoords, normVectors, vertInds) End If Dim tg As TransientGeometry = body.Application.TransientGeometry ' Calculate the range of the mesh. Dim smallPnt As Point = tg.CreatePoint(vertCoords(0), vertCoords(1), vertCoords(2)) Dim largePnt As Point = tg.CreatePoint(vertCoords(0), vertCoords(1), vertCoords(2)) For i As Integer = 1 To vertCount - 1 Dim vertX As Double = vertCoords(i * 3) Dim vertY As Double = vertCoords(i * 3 + 1) Dim vertZ As Double = vertCoords(i * 3 + 2) If vertX < smallPnt.X Then smallPnt.X = vertX End If If vertY < smallPnt.Y Then smallPnt.Y = vertY End If If vertZ < smallPnt.Z Then smallPnt.Z = vertZ End If If vertX > largePnt.X Then largePnt.X = vertX End If If vertY > largePnt.Y Then largePnt.Y = vertY End If If vertZ > largePnt.Z Then largePnt.Z = vertZ End If Next ' Create and return a Box as the result. Dim newBox As Box = tg.CreateBox() newBox.MinPoint = smallPnt newBox.MaxPoint = largePnt Return newBox Catch ex As Exception Return Nothing End Try End Function
Arthur Knoors
So I saw the code to use
ExtentsWidth
ExtentsLength
ExtentsHeight
to create a stock size for a part
SyntaxEditor Code Snippet (ilogic)
Thickness = Measure.ExtentsLength If Measure.ExtentsWidth > Measure.ExtentsLength Then Width = Measure.ExtentsWidth Else Thickness = Measure.ExtentsWidth Width = Measure.ExtentsLength End If If Measure.ExtentsHeight > Width Then Lenght = Measure.ExtentsHeight Else If Measure.ExtentsHeight > Thickness Then Lenght = Width Width = Measure.ExtentsHeight Else Lenght = Width Width = Thickness Thickness = Measure.ExtentsHeight End If End If
How can I use it in Visual Studio? I try but can not! Please help me one more!
Thank you!
For Vb.net:
Public Sub DimensionComponentSimple() dim ThisApplicationInv As Inventor.Application
Try Dim oInventorDoc As Inventor.Document 'oInventorDoc = ThisApplicationInv.ActiveDocument oInventorDoc = ThisApplicationInv.ActiveEditDocument If oInventorDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Or oInventorDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then Dim b As ComponentDefinition = Nothing If oInventorDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then Dim OinventorDocToBeDim As Inventor.AssemblyDocument OinventorDocToBeDim = oInventorDoc b = OinventorDocToBeDim.ComponentDefinition End If If oInventorDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then Dim OinventorDocToBeDim As Inventor.PartDocument OinventorDocToBeDim = oInventorDoc b = OinventorDocToBeDim.ComponentDefinition 'b = CType(oInventorDoc, Inventor.PartDocument).ComponentDefinition
End If Dim c As Box c = b.RangeBox Dim dmax As Point dmax = c.MaxPoint Dim dmin As Point dmin = c.MinPoint Dim dX As Decimal Dim dY As Decimal Dim dZ As Decimal Dim strLENGTH As Single Dim strWIDTH As Single Dim strTHICKNESS As Single dX = (dmax.X - dmin.X) * 10 dY = (dmax.Y - dmin.Y) * 10 dZ = (dmax.Z - dmin.Z) * 10 dX = Math.Round(dX, DocPrec) dY = Math.Round(dY, DocPrec) dZ = Math.Round(dZ, DocPrec) Try If dX = dY Then 'MsgBox("x") strLENGTH = dX '& " mm" strWIDTH = dY strTHICKNESS = dZ End If If dX = dZ Then strLENGTH = dX '& " mm" strWIDTH = dZ '& " mm" strTHICKNESS = dY End If If dZ = dY Then 'MsgBox("x") strLENGTH = dZ '& " mm" strWIDTH = dY strTHICKNESS = dX End If If dX > dY And dX > dZ Then 'MsgBox "x" strLENGTH = dX If dY > dZ Then strWIDTH = dY strTHICKNESS = dZ Else strWIDTH = dZ strTHICKNESS = dY End If End If Catch ex As Exception End Try If dY > dZ And dY > dX Then 'MsgBox "y" strLENGTH = dY If dZ > dX Then strWIDTH = dZ strTHICKNESS = dX Else strWIDTH = dX strTHICKNESS = dZ End If End If If dZ > dX And dZ > dY Then 'MsgBox "z" strLENGTH = dZ If dX > dY Then strWIDTH = dX strTHICKNESS = dY Else strWIDTH = dY strTHICKNESS = dX End If End If Dim LENGTH As [Property] Dim WIDTH As [Property] Dim THICKNESS As [Property] Dim StockNumber As [Property] Dim RoutineDimensioned As [Property] Dim DimensionDirty As Boolean = False Try LENGTH = oInventorDoc.PropertySets.Item("User Defined Properties").Add("", "LENGTH") If Not LENGTH.Expression = strLENGTH & " mm" Then '(dmax.X - dmin.X) * 10 & " mm" LENGTH.Expression = strLENGTH & " mm" DimensionDirty = True End If Catch ex As Exception LENGTH = oInventorDoc.PropertySets.Item("User Defined Properties").Item("LENGTH") If Not LENGTH.Expression = strLENGTH & " mm" Then '(dmax.X - dmin.X) * 10 & " mm" LENGTH.Expression = strLENGTH & " mm" DimensionDirty = True End If End Try Try WIDTH = oInventorDoc.PropertySets.Item("User Defined Properties").Add("", "WIDTH") If Not WIDTH.Expression = strWIDTH & " mm" Then '(dmax.Y - dmin.Y) * 10 & " mm" WIDTH.Expression = strWIDTH & " mm" DimensionDirty = True End If Catch ex As Exception WIDTH = oInventorDoc.PropertySets.Item("User Defined Properties").Item("WIDTH") If Not WIDTH.Expression = strWIDTH & " mm" Then '(dmax.Y - dmin.Y) * 10 & " mm" WIDTH.Expression = strWIDTH & " mm" DimensionDirty = True End If End Try Try THICKNESS = oInventorDoc.PropertySets.Item("User Defined Properties").Add("", "THICKNESS") If Not THICKNESS.Expression = strTHICKNESS & " mm" Then '(dmax.z - dmin.z) * 10 & " mm" THICKNESS.Expression = strTHICKNESS & " mm" DimensionDirty = True End If Catch ex As Exception THICKNESS = oInventorDoc.PropertySets.Item("User Defined Properties").Item("THICKNESS") If Not THICKNESS.Expression = strTHICKNESS & " mm" Then '(dmax.z - dmin.z) * 10 & " mm" THICKNESS.Expression = strTHICKNESS & " mm" DimensionDirty = True End If End Try Try StockNumber = oInventorDoc.PropertySets.Item("Design Tracking Properties").Item("Stock Number") If Not StockNumber.Expression = "=<Width> x <Thickness>" Then StockNumber.Expression = "=<Width> x <Thickness>" End If Catch ex As Exception MsgBox("Stock Number Error: " & ex.Message) End Try 'Only show message if needed on dirty property If oInventorDoc.Dirty = True Then If DimensionDirty = True Then msgbox = "Dimensions of " & oInventorDoc.DisplayName & " :" & LENGTH.Expression & " x " & WIDTH.Expression & " x " & THICKNESS.Expression End If End If End If Catch ex As Exception MsgBox("Error Dimensioning: " & ex.Message) End Try End Sub
Arthur Knoors
Hi Bradeneurope,
Thank you for your help.
Manymany Thanks!
Hi Bradeneurope,
Please help me. Now I can calculate the stock number for parts in the context Assembly. But I have a problem is I can not finish edit part in assembly by code.
Can you suggest me another way that no need to edit part in the context ass, please?
Here is the code:
Imports System
Imports Inventor
Public Class Form1
Dim assemblyDoc As Inventor.AssemblyDocument
assemblyDoc = invApp.ActiveEditDocument
Dim assemblyDef As Inventor.AssemblyComponentDefinition
assemblyDef = assemblyDoc.ComponentDefinition
Dim oComponentOccurrence As Inventor.ComponentOccurrence
For Each oComponentOccurrence In assemblyDef.Occurrences
Dim oBox As Inventor.Box
oBox = oComponentOccurrence.RangeBox
Dim dmax As Point
dmax = oBox.MaxPoint
Dim dmin As Point
dmin = oBox.MinPoint
Dim dX As Decimal
Dim dY As Decimal
Dim dZ As Decimal
Dim strLength As Single
Dim strWidth As Single
Dim strThickness As Single
Dim docPrec As Integer
dX = Math.Round(dX, docPrec)
dY = Math.Round(dY, docPrec)
dZ = Math.Round(dZ, docPrec)
Try
If dX = dY Then
strLength = dX
strWidth = dY
strThickness = dZ
End If
If dY = dZ Then
strLength = dX
strWidth = dZ
strThickness = dY
End If
If dX = dZ Then
strLength = dZ
strWidth = dY
strThickness = dX
End If
strLength = dX
If dY > dZ Then
strWidth = dY
strThickness = dZ
Else
strWidth = dZ
strThickness = dY
End If
End If
End Try
If dY > dX And dY > dZ Then
strLength = dY
If dX > dZ Then
strWidth = dX
strThickness = dZ
Else
strWidth = dZ
strThickness = dX
End If
End If
strLength = dZ
If dX > dY Then
strWidth = dX
strThickness = dY
Else
strWidth = dY
strThickness = dX
End If
End If
MsgBox("Stock Number of " & oComponentOccurrence.Name & "is: " & strLength & " mm x " & strWidth & " mm x " & strThickness & " mm")
oComponentOccurrence.Edit()
Dim length As [Property]
Dim dimensiondirty As Boolean = False
partDoc = invApp.ActiveEditDocument
Try
length = partDoc.PropertySets.Item("User Defined Properties").Add("", "Length")
If Not length.Expression = strLength & " mm" Then
dimensiondirty = True
End If
length = partDoc.PropertySets.Item("User Defined Properties").Item("Length")
End If
End Try
Next
End Sub
End Sub
End Class
Thank you so much
Ngoc Son
Inventor's User
Hello. I am new to the subject of Inventor VBA programming, and I also do not understand how to make the "calcualteTightBoundingBox(Body)" in the following code
(source: https://modthemachine.typepad.com/my_weblog/2017/06/getting-the-overall-size-of-parts.html) :
Set body = ThisApplication.CommandManager.Pick(kPartBodyFilter, "Select the body.")
Dim bndBox As Box
Set bndBox = calculateTightBoundingBox(body)
Set partDoc = ThisApplication.ActiveDocument
Dim sk As Sketch3D
Set sk = partDoc.ComponentDefinition.Sketches3D.Add()
Set lines = sk.SketchLines3D
Set tg = ThisApplication.TransientGeometry
Dim minXYZ As Point
Set minXYZ = bndBox.MinPoint
Set minXYmaxZ = tg.CreatePoint(bndBox.MinPoint.x, bndBox.MinPoint.y, bndBox.MaxPoint.Z)
Set minXmaxYZ = tg.CreatePoint(bndBox.MinPoint.x, bndBox.MaxPoint.y, bndBox.MaxPoint.Z)
Set minXZmaxY = tg.CreatePoint(bndBox.MinPoint.x, bndBox.MaxPoint.y, bndBox.MinPoint.Z)
Dim maxXYZ As Point
Set maxXYZ = bndBox.MaxPoint
Set maxXYminZ = tg.CreatePoint(bndBox.MaxPoint.x, bndBox.MaxPoint.y, bndBox.MinPoint.Z)
Set maxXZminY = tg.CreatePoint(bndBox.MaxPoint.x, bndBox.MinPoint.y, bndBox.MaxPoint.Z)
Set maxXminYZ = tg.CreatePoint(bndBox.MaxPoint.x, bndBox.MinPoint.y, bndBox.MinPoint.Z)
Call lines.AddByTwoPoints(minXYZ, minXYmaxZ)
Call lines.AddByTwoPoints(minXYZ, minXZmaxY)
Call lines.AddByTwoPoints(minXZmaxY, minXmaxYZ)
Call lines.AddByTwoPoints(minXYmaxZ, minXmaxYZ)
Call lines.AddByTwoPoints(maxXYZ, maxXYminZ)
Call lines.AddByTwoPoints(maxXYZ, maxXZminY)
Call lines.AddByTwoPoints(maxXYminZ, maxXminYZ)
Call lines.AddByTwoPoints(maxXZminY, maxXminYZ)
Call lines.AddByTwoPoints(minXYZ, maxXminYZ)
Call lines.AddByTwoPoints(minXYmaxZ, maxXZminY)
Call lines.AddByTwoPoints(minXmaxYZ, maxXYZ)
Call lines.AddByTwoPoints(minXZmaxY, maxXYminZ)
End Sub
Hello
There are the codetags missing around the function, so it looks a little confusing. The complete VBA Code is
Dim bndBox As Box
Dim sk As Sketch3D
Dim minXYZ As Point
Dim maxXYZ As Point
End Sub
On Error GoTo ErrorFound
Dim vertCount As Long
Dim facetCount As Long
Dim vertInds() As Long
Dim i As Integer
bestTol = tols(0)
For i = 1 To tolCount - 1
bestTol = tols(i)
End If
Next
Call body.GetExistingFacets(bestTol, vertCount, facetCount, vertCoords, normVectors, vertInds)
Else
Call body.CalculateFacets(Tolerance, vertCount, facetCount, vertCoords, normVectors, vertInds)
End If
Set smallPnt = tg.CreatePoint(vertCoords(0), vertCoords(1), vertCoords(2))
Set largePnt = tg.CreatePoint(vertCoords(0), vertCoords(1), vertCoords(2))
For i = 1 To vertCount - 1
Dim vertX As Double
Dim vertY As Double
Dim vertZ As Double
vertX = vertCoords(i * 3)
vertY = vertCoords(i * 3 + 1)
vertZ = vertCoords(i * 3 + 2)
If vertX < smallPnt.x Then
smallPnt.x = vertX
End If
If vertY < smallPnt.y Then
smallPnt.y = vertY
End If
smallPnt.Z = vertZ
End If
If vertX > largePnt.x Then
largePnt.x = vertX
End If
If vertY > largePnt.y Then
largePnt.y = vertY
End If
largePnt.Z = vertZ
End If
Next
Set calculateTightBoundingBox = tg.CreateBox()
calculateTightBoundingBox.MinPoint = smallPnt
calculateTightBoundingBox.MaxPoint = largePnt
Exit Function
ErrorFound:
Set calculateTightBoundingBox = Nothing
Exit Function
End Function
